Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > Z Series (Z3, Z4, Z8)
Z Series (Z3, Z4, Z8) General discussion and technical help for all year Z series cars.
Old 10-04-2010, 02:59 PM   #1
Broke By Monday
Name: Broke By Monday
Your Ride: 2000 Z3
2000 Z3 , a few questions....
New member from Cleveland here....
Just purchased a 2000 Z3 w/ 118,000 miles on it. I have a few questions if anybody has some answers i would greatly appreciate it.
1) The radio code is no where to be found. Pushed the M button and help, did not spit out any serial # or anything...any advice?
2) The traction control light was (is) on, so i pushed the button. I pushed it right through the dash and the front part of the button dropped down in there somewhere.
3) Airbag light is on, no reason it should be on.
4) Got it back from body shop for minor hood repair. It seemed to burn some oil off the right side of the engine pretty hard for a moment, drove it another 30 miles after that day, no issue at all. Also, Service Engine Soon light came on.
5) Power top seems to work when it wants to, seems like maybe a bad switch ? Always goes back on easy, sometimes have to play with switch for a while to get it to go down.
Other than that.....runs good, drives real nice and a real nice price.
Thanks,
Brian
Old 10-07-2010, 08:40 AM   #2
95325i
95325i's Avatar
Rate My Car: 290 / 337
Your Ride: 1997 540IA;2001 Z3 3.0 Roadster
-If you go down to the dealer with your car's registration card (from the DMV) and your ID BMW will give you the radio code for the original radio that was in the car.
-Take the dash board apart and push the button back into its seated place on the dash. As far as the traction control is it just the light in the middle of the dash or is it the traction control and a yellow brake light as well?
- The light could be on for a reason have you gotten the code read? if it is really for no reason the light could be turned off with the SRS code reader.
- My fathers 330 is doing the same thing. more then likely just poor maintenance by the last owner(s) and warn out seals. Its up to you if you want to spend the money or take the time to rip the engine apart. As for your SES light autozone or a BMW indy can get the code read for you and tell you what the car will need. It indicates that there is a failure in one of the emissions controls in the car.
-I have no idea why you are having this issue, but could be a switch, could be a loss wire some where between the top motor and the switch, could be the brake senor (my car I need to hold down the brake to raise and lower my roof) my simplest answer would to just make the top a manual roof since their is not much to lowering/ raising it.
1997 540IA
Old 10-09-2010, 04:36 PM   #3
JodyC
JodyC's Avatar
Your Ride: 2001 Z3
You can also try this site for the radio code!
http://http://www.radio-code.co.uk/bmw-radio-codes.html
97 BMW Z3 - Greetings BMWZ3 Introductions and Greetings 0 06-01-2010 11:58 AM
Z3 Suspension.(soft or hard) Keith T Z Series (Z3, Z4, Z8) 3 10-12-2008 06:03 PM
2000 328ci for $8500 NICE CAR joeblow4ya Bmw Cars For Sale/Wanted 2 03-08-2008 12:10 AM
New member Rochester, NY 2000 M5 help! mik911 M5 7 11-05-2007 08:18 PM
Bulb Replacement/ and other questions. ///Menace328i E36 0 05-13-2005 10:07 AM
