Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Off Topic > United Off Topic  **FOR MEMBERS ONLY**
United Off Topic  **FOR MEMBERS ONLY** Chat about whatever! Off-topic chat forum. (Be sure to appropriately title posts that are NWS) You must be registred and logged in to see sub-forums
Old 06-15-2006, 09:28 PM   #1
Chris
Chris's Avatar
Title: Visiting Mod
check control light
the check control light just came on and it says brake light circuit check owners manual.....
i would check the owners manual, but well... we don't have one.
can someone maybe look it up for me in their E36 manual?
Old 06-15-2006, 10:05 PM   #2
ChrisWorrell
Your Ride: 2004 330i
I think i remember reading about this
Common problem that happened in alot of e36, nothing is actually wrong, but rather bmw didn't seal the trunk perfectly and there are some wires that i believe have the chance to get wet, it doesn't brake anything but it sends a false signal to the computer saying something is wrong.
i could be entirely wrong but i think that was the cause of the problem
Old 06-15-2006, 11:45 PM   #3
Chris
Chris's Avatar
Title: Visiting Mod
thats probably it. the light went out when i turned it off completely removed the key and restarted.
Old 06-16-2006, 12:26 AM   #4
Rate My Car: 183 / 337
fool around with your tail light bulbs/sockets, and if those are ok, there is a 10 dollar brake switch right at the brake pedal, that may be the problem too
Old 06-16-2006, 05:02 AM   #5
Rate My Car: 106 / 337
Originally Posted by ChrisWorrell
Common problem that happened in alot of e36, nothing is actually wrong, but rather bmw didn't seal the trunk perfectly and there are some wires that i believe have the chance to get wet . .
Actually it's the seal on the tail light lenses. Rain or water is supposed to channel along the outer edges of the trunk, and drains down alongside the inner edges of the tail lights. But if the seals on the lights are weak, you'll get moisture in there. The Check Control measures resistance to current, so if you have corrosion from moisture, it'll raise the resistance and trigger the warning. Try cleaning the bulb socket contacts. Also, as xsperf mentioned it can be the brake switch located on the pedal. That can be tricky because it can trigger the warning even if it still seems to work.
That's how you reset the Check Control . . the warning will remain until you do that
Old 06-16-2006, 12:43 PM   #6
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 313 / 337
I got that problem before. Changed the Brake light swith and the sign is gone forever.
.BMW 328
Check engine light??? SHAHAB323IS E36 30 08-11-2011 11:50 AM
Check Light? Empty Box E21, E30 5 05-04-2006 05:13 PM
ABS check light came on!!! please HELP!!!! delmarco E36 9 07-06-2005 08:27 PM
90k mile tune up BombSquad E36 1 04-28-2005 12:09 AM
