Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > E36
FAQ Members List Calendar Advertise With Us Mark Forums Read
E36 General discussion and technical help for (E36) 1992-1999 3 series cars. 318, 323, 325, 328.
Unread 01-09-2011, 01:57 PM   #1
brian mahony
Your Ride: 1997 e36 saloon blue 1.8l
e36 model 1.8 coolant loss head gasket ok
over the last 2 weeks i have lost about a 3rd of a litre of coolant from my radiator..its a 97 318 e36 saloon with 170,ooo miles..we replaced the battery..topped up the oil..changed the wheels for bmw 3 series wheels..replaced the pollen filter which was in there since 97..when we checked the coolant it was full of all sorts of ----+crap..buddy is a mechanic well trained and everything was ok..since new years day i have lost about a 3rd of coolant from rad..no leaks from anywhere..heating system have been vastly improved since all the work we did to it..no more crap in the rad ..is this normal or what ..car is running away no problems..not overheating or such like..IS THIS NORMAL FOR E36 MODEL OR AM I BEING PARANOID..THIS IS MY THIRD E36 SINCE MARCH LAST YEAR AND I HAD TO TOP UP EITHER WITH COOLANT/WATER AT LEAST ONCE A WEEK
Unread 01-10-2011, 01:01 AM   #2
Manolito
Rate My Car: 339 / 340
Your Ride: (2) '97 328s; '04 330; '04 325iT
How full are you filling the reservoir? Anything much above the "cold" line will get pushed out the cap when the car gets to full operating temperature.
It sounds like you changed the coolant two weeks ago. It may be that there was still a bit of air in the system, so as that air worked its way out to the reservoir, you appeared to loose a third of a liter of water.
If you are filling it only to the cold line, normal evaporative loss for my four BMWs (two e36 and two e46s currently in the fleet) is about a half cup a every couple of months of daily driving. That is a bit more than my Volvos used to lose. I use BMW coolant and distilled water, and add distilled water between coolant changes.
Unread 01-10-2011, 07:52 AM   #3
3050rpm
3050rpm's Avatar
Your Ride: 1995 325i
Check the integrity of other cooling system components, such as a cracked radiator neck or expansion tank, hoses, connections, and the heater control valve. Given the age of the car, and its apparent lack of regular maintenance, a lot of rubber and other components may be well past the time for replacement.
Unread 01-10-2011, 01:04 PM   #4
brian mahony
went on a long spin today and the level is still at the same level..we put in a good bit of coloured ccolant and marked the level with a pen..still same level..as i said no leaks or anything ..freezing weather here in lreland so heating is working good..inside the rad is also clean only coolant in it and no rust/leaks anywhere..have to keep an eye on it all the same..
Unread 01-14-2011, 03:39 PM   #5
Big Evil
Big Evil's Avatar
Title: Moderator
Your Ride: 1994 BMW 525i, 1987 325is, 1986 325
I'm with 3050, it sounds like you have a leak when its warmed up.....which would likely be a radiator tank. Heats up and leaks, cools down and doesn't. But you're doing the right thing by monitoring it, let us know what you find
Big Evil, The BMW driving monster of the American Southwest (Currently on BMW #5)
Unread 01-15-2011, 05:08 AM   #6
brian mahony
seems to be running at the same level all week..should be ok now....
Unread 01-15-2011, 10:16 PM   #7
Big Evil
Big Evil's Avatar
Title: Moderator
Maybe just an air bubble then. Keep and eye on it obviously, but that sounds like good news.
Unread 01-21-2011, 12:31 PM   #8
brian mahony
level still the same in the rad...
Unread 06-11-2011, 10:49 AM   #9
brett murphy
Your Ride: 2000 bmw e46
no this is not normal and even though you cant see the coolant loss you need to have the system pressure tested to help determine the cause
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 33 08-11-2012 01:00 PM
E36 318is 1999 Barbie1973 E36 4 10-12-2010 11:47 AM
Overheating after Head Gasket Replacement? Serge E36 1 07-12-2009 10:48 AM
Overflow Coolant cap on E36 Mercenary(FH) E36 10 04-06-2007 10:31 AM
E30 325i M20 head gasket witeshark E21, E30 5 06-19-2005 12:57 AM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
