Unread 01-05-2007, 07:19 PM   #1
eavery19
Your Ride: 1998 328is
Brake Light Failure
1998 328is right brake light failure. After changing the failed right brake light, the new bulb(s) tried two new ones, the new bulbs would not work either. Carefully cleaned all contacts and retried, but still no brake lights. The car has been parked for about 15 days. All other rear lights are working properly, including the left brake light.
Any ideas???
Unread 01-05-2007, 10:00 PM   #2
Does your OBC (computer below your air conditioning) say tail light failure, or tail light circuit failure?
It might be a wiring issue.
Try taking the old (bad) bulb out of the right tail light and seeing if it turns on in the left side. If it does, it's something beyond the bulb, like wiring.
Unread 01-06-2007, 01:50 AM   #3
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
try switching sockets from the other side that is working i get this shit all day everyday
Unread 01-06-2007, 09:11 AM   #4
Unread 01-07-2007, 10:23 AM   #5
Kiterunner
Like what defkon99 said, try switching the sockets and see if the OBC shows any message. Heard from mechs of the local bimmer dealer that after a period of 7-8 years, the inner PCB tends to bloat / gloat or bend due to the heat generated by the brake light bulbs.
Also you may notice a slight burn-out or short-circuited crater in the contact points.
Unread 01-07-2007, 04:50 PM   #6
eavery19
Switched bulbs and switched sockets, light remained out. Is the PCB the gasket?
Unread 01-07-2007, 07:16 PM   #7
Kiterunner
PCB stands for the Printed Circuit Board, similar to waht we get in handphones. A simpler version to connect the circuitry. Worst case,. look for a replacement. I guess some UB memberd might have a set lying around after their upgrade. GOOD LUCK.
Unread 01-08-2007, 11:44 PM   #8
BhndTheWheel
Your Ride: '94 325is
Send a message via Yahoo to BhndTheWheel
I was getting this too on my car. I checked all the socket connections and made sure they were clean before replacing them. When I did that it turned off the warning message in the dash. I was also told to replace the "Brake Light Circuit" underneath the dash. I didn't have to go that route yet but it's an inexpensive part to buy; just cumbersome to snap it out and replace.
Unread 01-17-2007, 05:55 PM   #9
Reddots89
Your Ride: 96' 328ic, 01' Honda s2000, 97' vw jetta
Send a message via AIM to Reddots89
i got a brake light circuit off ebay for like 25 bucks, it was harder to replace it than anything. you have to break the old one out practically
Unread 01-17-2007, 06:54 PM   #10
I got my brake light circuit for $20 shipped or so
Unread 07-01-2011, 12:50 PM   #11
adamcammack
I had this same exact problem.
For me, it was a wiring issue. Open up your trunk and on the left side, you have your wiring harness that runs through. After repeatedly opening and closing the trunk, it can wear down and fray or even completely snap wires. So split open the protective rubber hosing and inspect your wires at the point where they are bent repeatedly. You just might find a frayed or split wire.
Hope this helps. I have a really good feeling that this is your problem.
Unread 07-02-2011, 09:56 PM   #12
The wiring in the trunk lid will cause the lock and license plate light to not work, but it won't affect brake lights which are on the car body.
e36 tail lights are also prone to burn through the traces when the sockets get corroded. My daughter pulled off her tail light and soldered shut the holes in the trace where the socket contact touches. Holding so far a year later, but eventually she will get new tail lights since hers are original and are pretty discolored.
Unread 09-06-2011, 08:32 PM   #13
runnr548
Rate My Car: 315 / 340
Your Ride: 97 328is, 01 325i & 09 328i
Send a message via Skype™ to runnr548
It is an all too common problem. We replaced the tail lights in my son's 98 328is. They were used, but in great condition. After replacing a few bulbs all was well. Later that day, we got the "tail light circuit failure" message, and it will not go away. The lights are working great none the less.
Unread 09-08-2011, 12:17 AM   #14
The Brake Light Circuit warning is normally the brake light switch on the pedal.
Crush out the old one with a big pair of pliers.
Don't buy a switch made in China.
Should cost about $35 on line.
Unread 09-09-2011, 08:30 AM   #15
Just keep in mind that there is a 2-pin and a 4-pin switch, and I don't know what distinguishes whether one's car has one or the other. Might be model year, might be stability control or whatever, but using your VIN you should be able to get the one you need.
Brake Light Circuits cruzn4abruzn E36 6 12-08-2014 09:01 AM
Brake light circuit problem BBizzle4888 E12, E28, E34, E39, E60 9 12-08-2014 08:47 AM
brake pad warning light DEATH2000 E36 14 10-17-2012 06:49 PM
Brake light circuit kjprince E36 0 03-27-2006 08:44 PM
3rd brake light Dudesky E36 6 08-18-2005 07:32 AM
