Unread 11-26-2006, 09:22 PM   #1
Unhappy Couple Problems...
Well i have a couple problems with my car right now and its pissing me off. Now remmber i live in Canada and its currently -30C right now so the cold may have something to with these.
First: When ever i turn the wheel 45* theres this wierd ratching noise. Like a socket wrench but softer and smoother. I have no idea what it is or what would cause it
Second: My door isnt closing. The mecanism that holds the door shut doesnt seem to wanna hold on. For some reason it wont grasp or lock. I cant even pull the lock nob on the door, the only way the door will actually stay closed is if i hold the door closed and then lock the car.
Now the second problem is the bigger one cause its hella cold and i have a 20min drive to and from work. I need my car bad so is this gonna be a big thing or is just because its spend so much time outside? It didnt do this last winter and it was just as cold out.
Unread 11-27-2006, 04:09 AM   #2
Re: problem #1 - it's pretty tough to diagnose without seeing & hearing it, could be anything from steering rack to power steering pump or front end parts
Re: #2 - you have it partially lock/latch jam. If you pull door panel off you'll probably notice or find clip missing or broken holding lock arm off or missing. Try working the lock from the outside w/key to see if it's just jammed or inbetween the actual lock settings.
Unread 11-27-2006, 10:47 AM   #3
Well with the lock the when the door is closed the key will enable it but only if the door is closed. It wont do it if its open.
grandparents want a car. zeaq328i United Off Topic  **FOR MEMBERS ONLY** 2 05-23-2006 11:47 PM
Dyno Problems with the E30 Turbo jrhaile E21, E30 6 10-27-2005 06:43 PM
problems Beelzibub E12, E28, E34, E39, E60 4 07-08-2005 08:33 AM
so any common problems with the 330? Numark318i E46 6 07-03-2005 01:21 AM
