Unread 10-16-2006, 06:43 PM   #1
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 286 / 340
Your Ride: 1993 BMW 325is
Smokey Oil smell from AC/Heat
So I've been noticing when i turn on the air conditioning or heating (note my ac comprssor is F**ked, so when i say ac, i mean jsut blowing air, thats non circulatingh (the little circle arrow thing isnt turned on)
but I notice when i do it, like when Im sitting, i can smell like an oily smoke smell coming from the vents.....Now I check my oil reguarly and it stays at the same level........what could be causing this?
Note: when i got my oil changed, my oil pan was "wet" but I dont think that'd have anything to do with it. and when i popped my hood.....I saw a little tuff of smoke like In the very very back of my engine kinda near the bottom.
I just got my valve cover gasket changed so i dont know if that has anything to do with it.......but, it was like VERY back under the engine, and it was so small i had to stick my head in to check.
any ideas guys?
Unread 10-16-2006, 06:49 PM   #2
I think it may be an oil leak that burns off some exhaust parts and the smoke comes over to the intake for the heat and AC
Unread 10-16-2006, 08:44 PM   #3
Mercenary(FH)
where is the intake located at?
because if thats so couldnt the oil pan thats "wet" and slightly leaking cause that? since it's kinda under near the back of the engine right? cause when i saw it smoke it was from way back in the engine ,very far back
Unread 10-19-2006, 10:32 AM   #4
Mercenary(FH)
anyone know where the vent is? I checked my oil and it doesnt look low?
Unread 10-27-2006, 01:06 AM   #5
Mercenary(FH)
Praise JESUS, it was only the valve cover gasket......that they already replaced, apparently it wasnt sealed correctly in the......u guessed it BACK LEFT COrner of the engine, right where I saw smoke. I drove it hard today, and guess what no smoke. I was worried it was head gasket, but.....thats not typical on bmw's. So i had to pay nothing. YAY
Unread 10-16-2007, 11:04 AM   #6
jboiv
jboiv's Avatar
Your Ride: 94 325ci
Send a message via AIM to jboiv
Question!!!
im having similar problems with my 94 325. smokey smell comng from vents when AC or "air" is turned on... When hood is popped little bit of smoke coming from tube in back left next to engine.. Any idea's...?? away from home so im reluctant to take to a new mechanic..
Unread 10-16-2007, 12:31 PM   #7
Seems like a small oil leak from the valve cover gasket as described in the previous posts
Unread 10-17-2007, 09:58 AM   #8
jboiv
jboiv's Avatar
Your Ride: 94 325ci
thankss. is it nessasary to get taken care or immedialty though?
Unread 10-17-2007, 10:13 AM   #9
I would try to, but as far as I know, I doubt it's urgent.
Unread 10-18-2007, 10:25 AM   #10
jboiv
jboiv's Avatar
Your Ride: 94 325ci
Thank You much
A bit worried, there's a very faint oil smell... xsperf E36 1 05-10-2006 11:27 AM
