Lighting
Sponsored by: BavToys.com
Unread 10-08-2006, 11:56 AM   #1
Tochenzo
Tochenzo's Avatar
Send a message via AIM to Tochenzo
fog light problem HELP!
Ok so my driverside foglight went out a few weeks ago, I changed the bulbs around and found out it was a bulb that was out. The burnt bulb is on the passenger side now and the old working bulb is on the driver side. I replaced the burnt bulb with a new one and everything was working, then later last night the passenger side fog light (side that i put the new bulb in) went out again. I checked the bulb, the filament and everything looked fine on both bulbs so i checked to see if it was a fuse/relay issue. Fuse looked fine, even put in a new one just in case, and the relay looked fine (not sure how to check the relay for working order). I put up a volt meter to the brown/yellow wires leading up to the fog light housing to see if it was a wiring problem, both sides put up 12 volts consistantly. The green light in the dash turns on and everything, what is going on!??!?!
Sometimes when I press the fog light button, the green light flickers before turning on or doesn't turn on at all until I press it a few more times (this has always happened so i don't think it's the cause of any problems). Also, when I press the fog light button, there is a clicking sound coming out of the fuse box. Does this mean it could be a relay issue?
Everything seems to be working up to the housing, yet my fogs still won't turn on. And the housing seems fine because the bulb is in securely and everything is plugged in. Could it be a bad ground somewhere?
1998 Hellrot 328i
Unread 10-08-2006, 01:18 PM   #2
Seems like a short or as you say a bad ground that burns out the bulb
Unread 10-08-2006, 01:44 PM   #3
yea dont check the voltage, check the current coming to the fog lights, check the amperage(sp?)
Unread 10-09-2006, 10:56 PM   #4
Tochenzo
Tochenzo's Avatar
dumb questio, but what do i use to check the sp?
1998 Hellrot 328i
Unread 10-10-2006, 03:15 AM   #5
spell check...
Unread 10-10-2006, 05:18 PM   #6
This may not have something to do with your problem, but as a rule of thumb, always change bulbs in pairs, not just one side or the other. That way you don't end up with variances in electrical resistance. In some cases, the weaker bulb can burn out because the newer bulb is drawing more current.
Unread 10-10-2006, 11:32 PM   #7
you check your connections? I remember on my headlights not that long ago, the connections needed a little emory paper and then they were fine.
DIY How to replace fog light bulbs on an E46 sedan Rooz BMW OEM Parts Department DIY's & FAQ's 7 10-20-2008 09:21 AM
WTB: e36 fog light bracket, tweeters MrWonka Bmw Cars For Sale/Wanted 0 06-06-2006 12:30 AM
e36 driver side fog light brien4787 Bmw Cars For Sale/Wanted 3 11-29-2005 04:54 PM
WTB; E36 fog light brackets M.C. Sketuls Bmw Cars For Sale/Wanted 0 11-15-2005 08:29 AM
my lonely fog light isnt so lonely anymore brien4787 E36 18 11-08-2005 12:53 AM
