Unread 09-25-2006, 08:01 PM   #1
ixgarry
Where are sensors, how to test 'em
Wondering if I have a sensor problem, possibly disabling engine spark and current to my fuel pump. Can someone tell me where the sensors are that could cause this; ie. crank, impact.
Thanks,
Garry
Unread 09-25-2006, 09:17 PM   #2
Not sure I follow
Unread 09-25-2006, 09:53 PM   #3
You're going to have to be more specific as to what your problem is. There are a "bezillion" (well almost...lol) sensors on BMWs.
Unread 09-25-2006, 11:05 PM   #4
if your not getting current to your fuel pump, its probably not a sensor, the car doesnt sense whether or not to send fuel, it always sends fuel when its on, so i would check a fuse or a relay, however if you are getting fuel but not in the right amounts, i would suggest mass airflow sensor, throttle position sensor... etc, and if you arent getting a spark, i would check the coils, if you arent getting either i would check the ECU
Unread 10-10-2006, 05:02 PM   #5
ixgarry
Got it running again. Swapped an ECU with my chip in it, but still wasn't working, then noticed aftermarket relay humming when key was off and doing nothing when on. Apparently 2 poles were reversed. Got the right relay and I'm on the road again. Thanks for replies.
E92 M3 test mule shots..... chek 'em out Chris M3 15 06-30-2006 07:56 AM
Fun With E36 Gauge Cluster Test Functions bitcore BMW OEM Parts Department DIY's & FAQ's 1 05-04-2006 03:08 PM
The Test komodo Comedy Collection
5 10-11-2005 03:10 PM
Man passes drivers test on 272nd attempt Addicted? Comedy Collection
20 04-29-2005 02:37 PM
