Unread 09-25-2006, 03:38 PM   #1
bmw111
Your Ride: 1998 e36 coupe
help needed brothers
i am an owner of a bmw e36 318is coupe, i recentley had my car vandalised, my airbox was ripped out. i know i can replace that with an induction kit. i am having a problem with the fuel consumption and there is a lot of smoke coming from the car and also the performance is not the same. CAN ANYONE ADVISE IF I PUT ON INDUCTION KIT WILL THIS SOLVE THE PROBLEMS OR IS THERE MORE I NEED TO DO ????????????????????
Unread 09-25-2006, 03:42 PM   #2
Airbox being the intake and air filter? If so all u need to do is replace it and youll be fine. I recommend the Jim Conforti Cold Air Intake (CAI), very nice sound, gives you decent gain in hp.
Unread 09-25-2006, 03:45 PM   #3
bmw111
THANK FOR ADVICE BRO. tHE PROBLEMS I MENTIONED, DO YOU THINK ALL THESE THINGS CAN BE AFFECTED BECAUSE OF AIR FILTER IE BLACK SMOKE , BAD PERFORMANCE AND FUEL CONSUMPTION, I AM CURRENTLEY ONLY GETTING 20MPG WHERE AS BEFORE IT WAS ABOUT 35MPG PLEASE HELP.?
Unread 09-25-2006, 04:11 PM   #4
do you still have the sensors and stuff, without them you might have troubles. you might also want to make sure all the rubber lines are connected. I had one come off when i changed my air filter and i had a rough idle that would die.
Unread 09-25-2006, 04:17 PM   #5
bmw111
Hi Nick Nice Bimmer M8. Thanks For Your Mssg. Do You Think Not Having An Airbox Can Solve All These Problems Ie. Bad Performance, Lots Of Smoke And Heavy Fuel Consumption
Unread 09-25-2006, 04:18 PM   #6
Well first off, caps lock isnt a good thing.
The black smoke could be caused by carbon deposits but in ur case it probably isnt if it wasnt doing it before. Its probably that the mass air flow sensor (MAF) was riped out to and is causing the car to run rich. That would also explain the poor fuel consumption.
heres a pic of my intake to show u were it is:
Its the sqaure little box looking thing that sorta sits atop the hose behind the heat shield.
Unread 09-25-2006, 04:55 PM   #7
Is it also throwing a check engine code?
01 Civic Front Bumper DIY NEEDED! Orefus BMW OEM Parts Department DIY's & FAQ's 11 09-16-2006 11:30 AM
Urgent help needed, 316i. charterali E36 1 06-18-2006 06:49 AM
Good Yoga Class Needed CAPiTUL Video and other Multimedia 4 05-25-2006 04:29 PM
Much help needed boy1_ Z Series (Z3, Z4, Z8) 6 10-13-2005 12:14 AM
ZKW's coming, hlp needed pls Rooz E36 43 06-18-2005 08:54 PM
