Unread 09-20-2006, 10:17 PM   #1
habbie
habbie's Avatar
Title: Forum Sponsor
Rate My Car: 1 / 340
***PROJECTOR Z install guide version2***
ProjectorZ™II Xenon Headlight Installation Guide
Written exclusively for BavToys ProjectorZ™II Product
This step-by-step guide is designed to be used in together with other available documentation including headlight removal, wiring, and
general installation, and your BMW Z Owner’s Manual. The information contained herein is a guide only and may not include every
possible step required to successfully complete this install. By using this manual, the installer absolves all liability of BavToys and/or any
vendors retailing, wholesaling, or engaged in the sale/install of BavToys products. This guide is electronic because it is a work in
progress and may contain some omissions.
This installation will guide you through the following key steps:
1. Tool Requirement
2. Parts Identification
3. Headlight Removal
4. Headlight Install
5. Headlight Wiring
6. Optional Feature
1. Tool Requirement:
a) Complete Socket Set – Including Deep Wall Sockets
b) Torx Screw Driver or Bit Set
c) 2 Flat Head Screw Drivers – Small and Large
d) 2 Phillips Head Screw Drivers – Small and Large
e) Double-Sided Tape (for HID ballasts)
f) Needle-Nose Pliers
g) Standard Pliers
2. Parts Identification Standard Includes:
2 headlights, Turn Signal Bulbs, Chromium Angel Eyes,
Halogen Bulbs (Lo/Hi).
Optional Includes:
Standard + HID ballasts (2), HID Bulbs (pre-installed), 2 Adapters,
1 Wiring Harness (HID), 2 Resistors (gold)
HID Upgrades available are:
1) 35W Standard Analog OEM
2) 35W Slim Digital Lifetime Warranty
3) 50W Standard Analog
4) 50W Slim High End Kit Digital Lifetime Warranty
a. The headlight is held in place by bolts at all the corners and requires an 8mm socket to remove the screws holding the light inplace, Bumper removal is not required.
b. Once the screws are removed, carefully remove the 9005 and 9006connectors from the existing bulbs.
Re-installing the headlight is similar to installation. The new headlight is held in place by 4 screws (reuse the existing screws). Slide the headlight in, taking note of where the guide rails are. Loosely bolt everything together first before the final tightening.
a) Top mounting locations for the headlights should be attached last.
b) The back mounting screws are not visible on the photo but are located directly where the arrows are. These bolts should be lined up first. If the bolts do not line up, lower the large mounting knobs a little to make the headlight line up with the body best.
c) This is how the headlight should appear when it is completely situated back onto the body of the car with the mounting bracket.
Wiring Instructions Should Be Followed Immediately after Test Fitment
– DO NOT FULLY INSTALL THE LIGHT HERE – return back to this step
once all the wiring and testing has been completed to secure the
headlight in place.
6. Headlight Wiring (Step by Step)
A. 9006 Connector will plug directly into the headlight low beam plug (only on non- HID application) or the red connector from the HID ballast.
B. 9005 Connector will plug directly into the high beam plug coming out the back of the headlight
C. Driver’s side wiring is shorter for the turn signals and may need to be extended for the angel eyes for ease of installation. Once you have identified the low positive (blue) and negative (brown), you can cut the wires and splice in an extension. Again, this is only optional, but may help with the installation of the angel eyes. For illustrative purposes, we used electrical tape as insulation here. We recommend either doing a soldered connection with insulation such as heat shrink tubing.
D. Mount the angel eyes ballast in a vibration free manner and moisture free location.
6. Headlight Wiring (cont)
E. High Beam Connections without Xenon are simply plugging in the provided rubber cap’s plugs to the bulb and connected the 9005 connection from the car.
F. Angel Eyes power lead wires need to be routed out the back – just like the HID bulb wires (optional HID) and can be done by cutting a small slit nto the rubber boot
6a. Headlight Adjust (cont)
G. 2 wheels can be used to adjust the lights up and down– Center Wheel (G1) moves the projector housing up and down – Outside Wheel
(G2) moves the projector housingleft to right.
H. More pictures will be shown here, but wiring the angel eyes requires merely a tap to the power and ground of the turn signals. Shown connected to the body of the car, the connection can be made to the
turn signals (brown= ground & red=power) brown (-)and blue (+)wires using ordinary junction taps.
Unread 02-25-2008, 08:22 PM   #2
habbie
habbie's Avatar
DYI: **BavToys ANGEL EYES Install Guide E46** habbie Lighting DIY's 12 10-12-2012 11:11 PM
e36 Lighting Faq and TROUBLE SHOOT guide habbie Lighting DIY's 0 12-06-2007 08:47 PM
Projector36 HID e36 Install --Please Help!-- barnutz Lighting 2 11-04-2007 04:03 PM
DYI: **Predator ICE V2 QUICK Install GuidE ** BY Phil habbie Lighting DIY's 0 09-25-2007 12:18 AM
Very important, Alarm install, Shark injector, and custom fiberglass lip!? BaLAnCe17 E36 8 08-14-2006 11:39 PM
