Unread 09-19-2006, 10:23 AM   #1
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 286 / 340
Your Ride: 1993 BMW 325is
Oil Pan Gasket
So while I was getting my oil changed they said around my oil pan gasket was a lil "wet" but nothing major
im assuming the 3 series has an oil pan gasket, i was curious is it a PITA to replace and is the part itself inexpensive?
thx
btw they said no oher leaks, 119k and hardly any oil leaks. YAY
Unread 09-19-2006, 12:04 PM   #2
Unless someone out there has a trick they can share, it's bitch, and then some. The engine has to be lifted up off the mounts, and a bunch of stuff has to come off before you can do that You may be better off using Bar's Leaks Engine Oil Stop Leak, or switching to a higher viscosity oil.
Unread 09-19-2006, 03:11 PM   #3
Mercenary(FH)
hmm
well that sucks, altho he said it was very minor, and i've neevr noticed my oil going down cause it's just "wetness"
the part I assume is inexpenvie, labor would prolly cost me around oh 350 i'd say? does that sound normal for a normal garage
Unread 09-20-2006, 05:42 AM   #4
daki77
Your Ride: '93. e36 325i (EURO)
Send a message via MSN to daki77
Originally Posted by Dudesky
Unless someone out there has a trick they can share, it's bitch, and then some. The engine has to be lifted up off the mounts, and a bunch of stuff has to come off before you can do that ...
... I didn't know that! I was planning to remove oil pan on my next oil change, clean it and change oil pan gasket. I don't have leaks or anything, but I was thinking this was one of those "change it while you're there" things, like, for example valve cover gasket or something...
The car has A LOT of miles on it, and I've had it for six months only...I just wanted to "make sure", but I guess this is one of those things you don't touch unless you have a problem...
oil change disaster!!! bimmerdame E36 25 05-25-2005 04:26 PM
