Unread 09-13-2006, 10:16 PM   #1
DropTopM
Your Ride: 1999 M3
Angry Vibration 45-65 MPH
Can anyone help me figure out why my steering wheel vibrates when I drive between 45-65 MPH? When I am driving slow or 90MPH, the car drives perfect. Thank you for all of your help!
Unread 09-13-2006, 10:31 PM   #2
Linds
Linds's Avatar
Rate My Car: 70 / 340
Your Ride: 97 M3
Send a message via AIM to Linds
Someone can correct me here but I think the most common cause is unbalanced wheels.
Unread 09-13-2006, 10:37 PM   #3
you'r right
Unread 09-13-2006, 11:38 PM   #4
DropTopM
Your Ride: 1999 M3
Could it also be a bent wheel? My car was wrecked before and the front driver side suspension was replaced. I will take it to the shop to balance the wheels. Thank you.
Unread 09-13-2006, 11:40 PM   #5
Linds
Linds's Avatar
Your Ride: 97 M3
Yeah, bent wheel was my second guess. If it's not either of these I think this might also be a symptom of the flex disc (aka guibo) needing to be replaced. I'm not sure, though, I haven't had any problems with mine yet (knock wood).
Unread 09-14-2006, 08:35 AM   #6
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
yupp , i should be checkin mine pretty soon, but only if i can look at TIS or chilton to how to get to it.
Unread 09-14-2006, 08:44 AM   #7
jms
jms's Avatar
Title: ______
Rate My Car: 105 / 340
Your Ride: 99 328I Convertible
Send a message via AIM to jms
mine was actually cause by a ball joint and a weak control arm bushing, the ball joint would start the shimmy and the control arm would make it worse, but if I went faster it was fine and if I went slower it was fine, it really freaked me out.
Unread 09-14-2006, 12:14 PM   #8
you might also get some from a bad wheel bearing, but you would have a loud humming noise if it got to that point.
Unread 09-14-2006, 12:21 PM   #9
wheel bearing would make a humming noise when you move the steering wheel, especially on an e30.
bent wheel is easy (i've had two), it makes a rythmic thump-thump-thump
unbalenced wheels/tires are easy assuming it's really unbalenced. other than that, maybe something isn't tightened down all the way...
i'll admit it. i didn't tighten down every lug nut after i put my struts on and put it on the ground, i got too excited. a quick tighten and that stopped.
Unread 02-16-2008, 06:27 PM   #10
Neilsen
Neilsen's Avatar
Rate My Car: 226 / 340
Your Ride: 1990 BMW 325i
i had cupped tires in the front for a while and the thing shook like crazy. i never took it to 90 though
Unread 02-17-2008, 01:14 PM   #11
TheUniballer
TheUniballer's Avatar
Your Ride: 1993 BMW 325is
do you live in a snowy area, cause snow can throw off the balance too, have had it happen a lot
All I need is a BMW, a curvy road, and a little driving music...
Unread 02-17-2008, 02:09 PM   #12
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 255 / 340
Your Ride: 1997 328i
Did you try rotating your tires back to front? Note: if they are directional tires, left rear to the left front & right rear to right front! If they are not directional, then RF to LR & LF to RR! If the the vibration moves to the back then you know you have an issue with those wheels!!! If not , then you might have an issue with the front end components!
Unread 02-26-2009, 08:27 PM   #13
BadBimmerz
BadBimmerz's Avatar
Your Ride: 1996 Bmw M3 and 1990 525i
If you are running aftermarket wheels they may need a hub-centric ring to fit snuggly on tha hub... if you are running stock wheels then jus disreguard this but yeah start with wheel balance and then check the suspension components like ball joints and Control arm bushings which can cause similar symtoms as u were describing..
Unread 04-07-2010, 04:01 AM   #14
Raymond
Your Ride: 2004 M3
New to Forum,
Hello All!
Have a 04 M3 Coupe 6spd.
Sounds like wheel balance is off.
Rocks in tread or like the other post snow/ice.
Wish you luck with your toy.
Raymond
Unread 05-20-2010, 12:19 PM   #15
willie0915
willie0915's Avatar
Rate My Car: 138 / 340
Your Ride: M3 1995
Hello, may sound crazy, but if none above have result you can check the flex disc between the front section of the driveshaftand the output flange of the transmission should be checked for cracks, tears, missing pieces, or distortion. Check for worn bolt hole bores in the flange. It happends to me once and after I replace the flex, Problem solve.
Airplane Flight Question komodo United Off Topic  **FOR MEMBERS ONLY** 105 07-27-2007 09:35 AM
