Unread 09-10-2006, 12:17 PM   #1
Remove Taillights, Ck for Rust
Since my car is exposed to the elephants... e-r-r-r, elements, a lot of debris collects on the lip around the trunk, and then goes down to where the taillights fit in. Since it was a nice day, I got a little obsessive/compulsive and decided to pop out the taillights to see what lurked underneath. Yes, once they were out, there was a fair amount of grunge on both the assembly and the frame, easily removed though with a sponge or towel and warm soapy water (wax if you're really possessed). Everything looked okay with the left one, but with the right I found a patch of (mostly, I hope) surface rust running from the corner of the where the light goes, over to the rubber seal by the trunk. I think it can be easily dealt with, sand, rust converter, prime, paint, but I also think I'll have to lift a section of the rubber seal and peek under that to see how far it has extended.
Anyway, my point is, it's a simple enough check to see if a nefarious little leak has been working toward ill ends in a dark corner.
Removal of the lights is straightforward, undo four nuts, disconnect electrical connection (press tabs and gently use a screwdriver), and I suggest using a rubber hammer on the four exposed studs, the lights do form a rather tight seal against their rubber trim, and you otherwise really can't get enough pressure with your fingers to push them out, and certainly prying with a screwdriver is a no-no.
Unread 09-10-2006, 12:45 PM   #2
Heh thats a good idea. I found some rust in my trunk earlier this year. Everyone check you taillights...
Unread 09-11-2006, 05:55 AM   #3
jms
jms's Avatar
Title: ______
Rate My Car: 105 / 340
Your Ride: 99 328I Convertible
Send a message via AIM to jms
not a bad idea, I had a small section form on the back of my trunk lid at the weld seem, Fortunately it was only surface and I was able to sand it off and touch-up.
Unread 09-11-2006, 02:13 PM   #4
Mercenary(FH)
Mercenary(FH)'s Avatar
Rate My Car: 286 / 340
Your Ride: 1993 BMW 325is
surprisngly my car has never had rust problems, and its a 93' altho the top of my car has clear coat peeling off
how much is clear coat to replace lol
Unread 09-13-2006, 08:54 PM   #5
Alpine328i
Your Ride: Alpine White 1996 328i
Send a message via AIM to Alpine328i
"Replace" clear coat, lol....
Sorry, I just laughed....
Not making fun Mercenary, just your wording was funny....
---Bailey
"In the road of life there are Bimmers and there are Bimmers"
Mods: Full JDM lighting, APC bulbs, ///M rims, Four wheel Brembo rotors, Bilstein Touring suspension.
how to remove wheel centers-bbs type on '88 325is e30serg E21, E30 1 06-05-2006 07:28 PM
