Unread 08-23-2006, 07:50 PM   #1
projal147
Send a message via AIM to projal147
Exclamation MAJOR PROBLEM - Starting Car!!!! HELP!!!
Hey guys I know I have not been on in a looong time... anyways I need major help. My car will not start here is a list of things I have checked.
The car will turn and the engine cranks but there seems to be missing that last step of the actual start of the engine. The check engine light is also on.
I have checked the following:
1) Battey, the voltage across the battery is approx 12V (I dont have a digital meter so the needle is at 12V)
2) The car code check returns 1444 which indicates no faults.
3) Removed the connector to the spark plug and put a screw driver into the connector and tried to start the car, there were sparks.
4) Fuses for fuel pump and fuel pump relay the fuses are not blow.
5) Jump the car. The engine still just cranks and wont start.
I have changed the following in the last day just before the problems started:
1) front breaks and wear sensor
2) air filter
I actually had a problem with starting the car on tuesday afternoon, it started idled for about a 5 seconds and then stalled. After 2 attempts of starting the engine, I tried starting it while pressing the gas pedal, and the car started right up and idled fine and drove fine. I drove the car for about 25 miles after that and stopped and restarted the car about 3 times later that day/night after the trouble.
This morning I go to start my car and I have the same problem. The car starts and then stalled after about 3 seconds. I try to restart but this time pressing on the gas pedal while cranking the engine. Nothing worked. The car did not start after repeated attempts.
Any thoughts.. HELP!!!
Member of "Ran From A Cop And Got Away" Club
My goal is to race in the Gumball 3000 by the age of 28.
New York Yankees - It's A New Year.
Unread 08-23-2006, 08:10 PM   #2
My first guess is the fuel pump isn't working. This is how my car acted when that failed
Unread 08-23-2006, 08:22 PM   #3
projal147
^^ How can I test that the fuel pump is bad...???
Unread 08-23-2006, 08:30 PM   #4
If you can get to where it is and hear if it runs for a second when you turn the key on. If it's like mine it's in the tank under the back seat
Unread 08-23-2006, 08:40 PM   #5
projal147
^^ yea mine is under the back seat... how loud is it?... i had put the key into the "on" position and tried to hear if the pump turned on but got nothing... tried it on my dad's car which has it in the trunk too and couldnt hear anything so i decided to ax that test...
how loud was it for you?
Unread 08-23-2006, 09:46 PM   #6
Just a low wirr, very hard to hear not sure you can hear it without removing the seat
Unread 08-23-2006, 10:06 PM   #7
if you have checked your ignition, and that is fine, then there almost 100% IS a problem with the fuel system, wherever it is
Unread 08-23-2006, 10:55 PM   #8
catalyst
Rate My Car: 195 / 340
Your Ride: 1994 325is
You need to remove the rear seat and listen for the pump, only way to really know whether or not its running. Its located underneath a black panel that is screwed down for access to the pump.
I had a similar problem in the e34 a couple weeks back, it turned out to be the crank shaft sensor.
Unread 08-24-2006, 05:04 AM   #9
How much gas is in your tank? You can easily burn out the pump motor if you're constantly running a 1/4 tank or less. The sound of the fuel pump can vary, depends on how old it is; a healthy pump should sound like a constant medium to high pitched buzzing. But you'll definitely hear something in there if it's working. Here's more:
http://www.unitedbimmer.com/forums/t...placement.html
Unread 08-24-2006, 07:30 PM   #10
projal147
thanks guys... yea i think its a prloblem with the fuel system I removed the rear seat and put my ear to the area where the fuel pump is and dont hear anything. The ignition i believe works and I have 3/4 of a tank of gas with only about 75-80 miles on the current tank.... A BMW mech who is a friend of a friend is coming over tomorrow to look at the car for me as a favor.. will update later
Unread 08-24-2006, 08:55 PM   #11
ok good luck
Unread 09-07-2006, 09:16 AM   #12
projal147
Update (9/5/06)
yea it was the fuel pump, got it fixed last week. only cost me the price of the part and a 12 pack for the mech's time.. lol its runnin great now... next thing I have to do is install new rear breaks, just did the fronts
Unread 09-07-2006, 11:18 AM   #13
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
sweet good to hear^^
24 01-22-2008 05:54 PM
You Might Be a Ricer If.... komodo Comedy Collection
20 11-08-2006 11:06 AM
Starting my car. catalyst E36 4 08-23-2006 11:21 AM
Car stalled and now engine won't turn over... looking for any ideas/help ChrisWorrell M3 0 05-21-2006 03:11 AM
Trouble starting car after sitting cold for 3 days..help!? delmarco E36 2 05-28-2005 09:26 AM
