Unread 09-15-2006, 11:58 AM   #61
dinan540
dinan540's Avatar
Nate,
Did you find an e30? Sweet if you did. Hey Devin, I fractured a bone in my right elbow playing soccer on Wednesday night. Working is tough and shifting is painful. I can't squeeze anything without a shooting pain going to my elbow. Soccer is out, lifting weights is out and wrenching on cars is out for at least six weeks. I can still run though. If we go to spokane, I might have you drive my car for parts of the drive and I think Rebecca wants to come and hang out in Coeur D Lane on Saturday. I think I will get a room at the Coeur D Lane resort.
540i with some mods
Unread 09-15-2006, 12:11 PM   #62
devinwwu
Rate My Car: 49 / 340
ya man i wouldn't want you wrenchin on my teeth like that!
it would be a huge burden for me but i guess i could maybe drive for a little bit...
Hope it heals fast man that sucks
Unread 09-15-2006, 06:22 PM   #63
devinwwu
just an image i found the other day of the exact stance and wheel tire setup i'm going to run.
borbet type T in 16x9s with stretched tires. he is also running a GC coilover setup!
one more GC setup
Unread 09-20-2006, 09:09 PM   #64
devinwwu
This son bitch is idling!!!!!
put the idle control valve in with the new oem piping conversion and it idled perfect at about 800rpm no questions asked!!!!.
Got my GC coilovers today as well as the front and rear koni adjustables, all the poly urethane bushings and trailing arms, sway bars and mounting hardware, pagid brake pads, brembo rotors and new dual in dual out magnaflow cat!!! gonna be install happy for the next few days!
Unread 09-20-2006, 09:24 PM   #65
sweet.
Unread 09-20-2006, 10:17 PM   #66
hope it goes smooth and w/out problems...
Unread 09-21-2006, 11:27 AM   #67
dinan540
dinan540's Avatar
That is awesome Devin. You must be so psyched.
540i with some mods
Unread 09-21-2006, 11:42 AM   #68
devinwwu
you have no idea paul. you should come check it out before i put the exhaust back on
Unread 09-22-2006, 01:06 PM   #69
devinwwu
so they upgraded me to the ireland engineering racing style camber plate. I'm stoked this is the description from ireland engineering:
Adjustable camber plates are absolutly essential for track cars. Our camber plates mount to the body from underneth the fender using the original mounting holes. These are designed for use with 2.5" ID springs and coil overs. With the 2.5" springs you can get up to 3 degrees negitive camber. Kit includes slotted mounting plates, sliding plates with steel spherical bearings, and 2.5" ID upper spring perches containing needle thrust bearings. Plates are machined from billet 6061T6 aluminum. Racers will probably want even more than 3 degrees camber. We usually bend the strut housings 1 to 1.5 degrees for racing.
Unread 09-22-2006, 02:22 PM   #70
dinan540
dinan540's Avatar
What are you up to this weekend? I can cruise by and check it out.
540i with some mods
Unread 09-22-2006, 04:36 PM   #71
devinwwu
workin on the car man go ahead and come check it out!! i'll be working on it tonight all night too! hopefully i'll have the suspension all in tonight
Unread 09-22-2006, 05:05 PM   #72
dinan540
dinan540's Avatar
I'll give you a call. I have services tonight, but tomorrow might be good.
540i with some mods
Unread 09-23-2006, 03:40 PM   #73
Addicted?
Title: 350z
any more news yet devo? i am going to go hit up chuckanut! to bad your coche is not up and running yet!
Give me a call
Unread 09-28-2006, 02:10 AM   #74
devinwwu
UPDATE###
I got the stromung exhaust in the mail today. damn this thing is gonna sound awesome!!!
Been busy with bushings (worst job ever!!!!!) stock ones take a lot of patience and willpower to get out and the new ones are almost as hard to put back in. Rear end is basically all done with the SS brake lines, rotors, pads, coilovers, TA bushings, subframe bushings, I'm waiting to do the diff mount until i get the LSD which should be the next thing on the list now.
Just need to bleed the brakes and the rear is set.
Front is IP, pass. strut has been removed, cut off the factory spring perch and put on the GC sleeves. Then put in the Koni Adjustables and mounted them up to the IE race camber plates up top. Will end up cutting the housing in the engine comp so that i can adj for full camber as they don't slide all the way right now. Tomorrow will be the other front strut, rotors, pads, and a full system bleed including the clutch slave which still needs to go in. then the car will be dropped onto the wheels for the first time as a 335i!!!!
Gonna be a noisy trip to the exhaust shop friday or saturday haha.
should have exhaust clips and video as soon as i can. i'm moving this weekend too so you may just have to be patient...
pics of the new parts will come tomorrow i'm thinking
<end tease>
Unread 09-28-2006, 03:43 PM   #75
Turbodefrost
Turbodefrost's Avatar
Your Ride: 1996 328is
Send a message via AIM to Turbodefrost Send a message via MSN to Turbodefrost Send a message via Yahoo to Turbodefrost
DAMN i can't wait till this thing is finished
E30 picnic dinan540 Bimmer Showroom 9 06-19-2006 08:11 AM
Project Track Car xsperf United Off Topic  **FOR MEMBERS ONLY** 0 04-14-2006 12:18 AM
My 97 Camry vs an e30 325e BMWLotAttendant Kill Stories 18 10-26-2005 12:38 AM
I think im buying an e30 catalyst E21, E30 13 07-19-2005 05:54 PM
