Unread 09-10-2006, 05:36 PM   #46
Congratz! That's a major FTMFW
Unread 09-10-2006, 06:55 PM   #47
howd you fix it?
Unread 09-10-2006, 09:17 PM   #48
devinwwu
Rate My Car: 49 / 340
when i was reading the m30 swap info on jared squires website (no decal performance, great site with great info) his m30 had the inlet and outlet for the fuel lines opposite of mine. So i was pumping fuel to the rail backwards through the regulator. obviously this wouldn't work and i realized this after looking at everything else. switched the lines and reset the ecu and connected the green wire of my c104 plug to the + of the coil and crank... crank.... enter sweet music of unmuffled m30 and the smell of thick exhaust. (first time the motor has been run for a month or so...
Unread 09-10-2006, 09:44 PM   #49
devinwwu
here's a quick vid i took tonight
http://files.unitedbimmer.com/ub.c/d...m30%20swap.mov
the car won't idle right now cause it doesn't have an icv my e34 didn't ever have one of these so i have to retrofit one from the old car somehow...
Unread 09-10-2006, 11:58 PM   #50
Spieluhr
Title: ///M Driven
damn dude, that's awesome! I'll head out this week and check it out.
Unread 09-11-2006, 12:41 AM   #51
BaLAnCe17
BaLAnCe17's Avatar
Your Ride: 1998 m3 coupe :-D
Send a message via AIM to BaLAnCe17
looks sick devin. i couldnt even imagine putting all that stuff together like that. what exhaust set up are u gonna go w/? sorry if i skipped over it on an earlier thread. you comin on the 23rd drive for sure yet?
Unread 09-11-2006, 10:23 AM   #52
devinwwu
not positive but if the car is done then ya! i have the time off. my gf will be moving back up to WWU so i'll be free. i have to get the driveshaft all mounted up, the shifter figured out and the cooling hoses are a little tricky.
the exhaust i''m going to run is a stromung. i know they sound amazing on the 3.0l m3 so i figure on a 3.5l e30 they'll sound even meaner!
Unread 09-11-2006, 10:55 AM   #53
jrhaile
Rate My Car: 114 / 340
omfg sounded so mean Devin
Unread 09-11-2006, 05:29 PM   #54
dinan540
dinan540's Avatar
Sweet Devin. I hope you have it running for the 23rd. It is looking as if I will be able to make the drive.
540i with some mods
Unread 09-11-2006, 06:11 PM   #55
devinwwu
if i dont' i'll for sure be ridin along with you. i can play camera man for a day or two. i think we are supposed to meet up with chea too.
Unread 09-12-2006, 12:45 AM   #56
dinan540
dinan540's Avatar
Last time I drove with Chea, he was a bit crazy. I get off work at 3 on Fridays. When will be off work? I just bought a camera mount for the car. So, if you vid, we can have the car camera facing toward the front or the rear. It mounts on a bar that connects to the head rest supports.
540i with some mods
Unread 09-13-2006, 01:23 PM   #57
devinwwu
nice man, i have the same setup from my old e34. I just purchased the exhaust pieces!!!
Magnaflow 98004 dual in dual out 2" catalytic converter
Stromung e30 m3 exhaust from understeer.com!!!! I can't wait to see how the 3.5 sounds on that system!
I'm planning on running the stock pipes to the magnaflow, then slipping 2.5" over the outlet and running dual 2.5 to the stromung. should be deep and loud!!!! with enough backpressure too i think
also buying the e30 shift carrier and reusing my e34 ssk cause aparently it will work. also found out the stock e30 driveshaft fits without modifications!!! it's exactly the right length i just have to make sure the carrier bearing is in the right place.
figured out the cooling last night as well. it was a little odd cause the e34 had an aux waterpump (electric) and 3 hoses to the interior heater area. the e30 only has 2. i had to make sure i had them right and then cut and clamp them on. hope it works.
also purchased a 14" permacool fan (high performance) 6 blade metal beast capable of pushing 2950 cfm through my radiator. that with some waterwetter and i think i'll be a ok.
Unread 09-14-2006, 10:08 PM   #58
devinwwu
just cause i'm really bored and very excited about the new exhaust!!!! here are some clips of it on an e36 m3. I believe chris has the 3.0l motor. just imagine how it will sound on a big 3.5l!!!!!
http://understeer.com/onlinestore-exhaust.shtml
scroll down to the end of the stromung systems and the links are there for the different clips
Unread 09-15-2006, 12:19 AM   #59
Spieluhr
Title: ///M Driven
sounds sweet man! this project will own all. and thanks for that e30 hook up, if i can scrape the funds and get in touch with the guy, it's mine!
Unread 09-15-2006, 10:15 AM   #60
devinwwu
always lookin out man! good luck with that!
E30 picnic dinan540 Bimmer Showroom 9 06-19-2006 08:11 AM
Project Track Car xsperf United Off Topic  **FOR MEMBERS ONLY** 0 04-14-2006 12:18 AM
My 97 Camry vs an e30 325e BMWLotAttendant Kill Stories 18 10-26-2005 12:38 AM
I think im buying an e30 catalyst E21, E30 13 07-19-2005 05:54 PM
