Unread 06-25-2006, 12:14 PM   #1
luispest
Your Ride: 2001 750IL
Service Engine Soon light reset
My coolant was a little low from a leaky hose and the Service Engine Soon light came on along with the Low Coolant fault.. I fixed the problem but can't find anywhere how to reset the darn thing. I have found the wire trick for the oil and service etc but not for this Service Engine Soon... Help me Please... Thanx in advance... Also looking for window regulators for the left side both front and back doors whent out.
Unread 06-26-2006, 10:06 PM   #2
AFAIK the reset tools are the best way. How soon to the next service? I have always got a service shop friend of mine to just do it or just wait until the next normal service.
Unread 06-26-2006, 10:49 PM   #3
Sometimes disconnecting battery for 2 minutes then reconnecting (negative cable last) will reset that. They sometime trigger when a minor issue arises as your sensor did. It's more of an annoying reminder to have someone look at it - especially a coolant issue.
Unread 06-27-2006, 10:30 PM   #4
luispest
Thanx for the help.. I just got it serviced but a month or so ago. I'll try the battery thing and see how that goes. If that does not work then I'll get the reset tool that I was planning on getting any how. Once again thank you...
Unread 06-28-2006, 09:05 AM   #5
odd, low coolant level should only show on your OBC, not the "service engine soon"
airbag light reset brien4787 E36 6 09-11-2011 12:41 PM
Check engine light??? SHAHAB323IS E36 30 08-11-2011 11:50 AM
Scanner & Warning Light reset CWatts Z Series (Z3, Z4, Z8) 0 06-08-2006 08:41 PM
