Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Forced Induction
Forced Induction Sponsored by: SmartAutoWarranty.com
Discuss Forced Induction on BMWs with SmartAutoWarranty.com (turbos and superchargers).
Unread 02-20-2007, 02:12 PM   #121
///M Power
Rate My Car: 26 / 340
Your Ride: 95 m3 turbo
Originally Posted by B_w.
lol...sort of...blew that rad while out tuning the other night so just waiting for all my new cooling components
You blew the radiator? Are you sure yoru system isn't getting pressurized. Did you torque down the head well enough? Check yyour upper raditor hose to see if it's getting very hard for extended periods fo time.
Unread 02-20-2007, 03:22 PM   #122
B_w.
Rate My Car: 62 / 340
Your Ride: turbo e36
lol...not exactly blown....the plastic endtanks cracked and finally broke completely...it had been leaking from there ever since i started it up again, it was the original rad, i think it just finally gave in. but yes i do need to retorque the head studs which i will do b4 it is started up again. no sign of oil or anything in the coolant.
Unread 02-26-2007, 12:57 AM   #123
matimus
matimus's Avatar
Your Ride: E30/S50 GT35R+ E30M3
Originally Posted by RSF5
This is UB's only turbo build isn't it?
nope, i wasnt going to but ill post details on mine for all to see.
Unread 03-20-2007, 09:53 PM   #124
matimus
matimus's Avatar
Byron, Update these guys !!! or i will.
ok ok ,i cant wait, I got a ride in byrons car
Its Mother F----ing fast!!! i was holding on for dear life. It was like the amusement ride "drop off doom" when you hold on so hard that you want to scream ( luckily i held it in, and retained my manliness and almost certain embaressment)
I also raced him from a roll in my E30 m3. we were even untill he hit third gear. How you ask? well, the roads were wet and it was 0 degrees celcius outside and he couldnt get any traction with the summer tires (untill ~100KM/HR) . I , on the other hand had it floored and NOT spinning, then he hiT some dry pavement and took off. IT was like he was shot out of a canon!!! instantly he was 3 cars ahead of me. at what? 10psi only? Byron your car is f___ing nuts!! i love it!!!
Post some pics for these guys.. especially the sexy one of the front end showing the intercooler
Unread 03-20-2007, 10:10 PM   #125
Wow
Unread 03-21-2007, 03:11 AM   #126
B_w.
hhaha, thanks mat, it is pretty quick. just need some drier and warmer roads which will hopefully help with traction a little. i guess its now in good enough working order that i could post some pics and take some video for you guys.
the e30 m3 is no slouch and i took off on this thing like it was standing still once i had traction by 140 kmh, which came almost instantly it seemed, the m3 seemed like it was maybe 10 cars back...maybe i am being optimistic but i didnt look too hard when i was doing almost 2.5 times the speed limit
keep in mind this is just with the base map i got with the tec3 and some slight changes i made to the fuel delivery to improve the a/f a bit.....very very conservative timing and running off the .7 bar waste gate spring which is just shy of 10psi...my guess is this is still well over 300whp when all said and done i hope to have my high boost setting at 14 psi and approx 440whp.
its getting closer and closer to being done...fixed the coolant leaks when i overhauled the cooling system but it still leaks oil everywhere also just replaced the battery as the old one was toast and couldnt hold a charge, still need to replace the alternator, swap in my uuc ceramettalic m5 clutch with steel flywheel, install new motor mounts and tranny bushings, ss brake lines, make a gauge pod to hold the ones where the obc used to be, and most importantly get it tuned!...its been one thing after another but in the end it will be worth every bit of time and money i have put into it
hey matt when you get some time you think you could please help me make a gauge mount like you did in your e30
Unread 03-21-2007, 04:02 AM   #127
matimus
matimus's Avatar
yeah absolutley, aluminum or fiberglass?
one day we'll do your clutch too. just let me know when.
Unread 03-21-2007, 12:11 PM   #128
B_w.
probably just aluminum i think....
Unread 03-21-2007, 10:27 PM   #129
matimus
matimus's Avatar
no problem. ill stop by tis weekend to start fitting
Unread 03-21-2007, 11:41 PM   #130
RSF5
RSF5's Avatar
Rate My Car: 278 / 340
Your Ride: NOOTHHHIIIINNG
Where are the f***ing PICS, I'm dying here man!!!
Unread 03-22-2007, 01:14 AM   #131
^^ ditto.
pics or ban. or something.
Unread 03-22-2007, 11:31 AM   #132
PICTURES please, and if im ever in edmonton both you guys are going to have to take me for a ride.
Unread 03-29-2007, 09:57 PM   #133
B_w.
ok guys...i funally have some pictures for you
and the new moldings
Unread 03-29-2007, 10:14 PM   #134
very nice, any kill stories?
Unread 03-29-2007, 10:16 PM   #135
This car should show up in car magazines
Technique Tuning stage 1 turbo kit dwrx04 Forced Induction 14 01-01-2007 05:14 PM
Ticco E30 Turbo video voca Video and other Multimedia 6 11-15-2005 04:02 PM
Turbo Parts komodo Forced Induction 4 09-26-2005 08:29 PM
sweet turbo sound beem Video and other Multimedia 10 05-22-2005 03:30 PM
turbo 325 Addicted? Video and other Multimedia 7 05-17-2005 03:47 PM
