Unread 12-27-2013, 12:51 PM   #1
Your Ride: 2004 325i
HELP! E90 325i Engine Vibration / Shaking
2006 BMW 325i
Mileage: 66,000
Symptoms – Extreme vibration and shaking of the entire vehicle at low RPMs with multiple codes as listed below. Engine vibration and shaking worse on cold start and when in reverse.
September 2013 Service Engine OBD Codes:
P0300 – Random/Multiple Cylinder Misfire Detected
P0153 – O2 Sensor Circuit Slow Response
Dealership Fix – Recommended draining fuel tank due to “low grade fuel”. Codes cleared.
Techron fuel additive added. Symptoms seemed to slightly improve.
November 2013 Service Engine OBD Codes:
P112D – Manufacturer Defined
Dealership Fix – Replace spark plugs because “the wrong spark plugs were installed” (although they were the factory plugs from original build and dealership purchase). Cost of $335 . Codes cleared.
Symptoms seemed to slightly improve but didn’t go away.
December 2013 Service Engine OBD Codes:
Vibration at low RPMs worse than ever. Not wanting to go back to the dealership for additional “fixes” that never cure the problem. Any suggestions would be greatly appreciated. I had originally thought that I might have a bad engine coil but haven’t yet attempted the replacement.
Unread 01-12-2014, 09:58 AM   #2
Are their any modifications to the vehicle such as a tune?
P0153 means your O2 sensor is not reading correctly. This could be because the sensor is defective or the wire from it is damaged. You will need to have it inspected. The car cant compensate the air/fuel ratio properly if it doesnt have a proper O2 reading which could be causing the misfire. If you get a "Bank 2 Sensor 1" code, then that is the passenger side, pre cat sensor.
X5d engine vibration leeella X Series (X3, X5,X6) 3 01-17-2012 11:00 PM
Looking for an engine for 89 325I Nstg8r BMW General Discussion 0 11-19-2009 08:53 PM
How do I reset the "service engine soon" for my 325i daveb 2002 4 07-23-2009 03:36 PM
325e engine swap (325i) Processes PhotoGuy30523 E21, E30 3 08-15-2006 04:17 PM
