Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > E36
FAQ Members List Calendar Advertise With Us Mark Forums Read
E36 General discussion and technical help for (E36) 1992-1999 3 series cars. 318, 323, 325, 328.
Unread 06-30-2013, 12:46 PM   #1
rosesette
Your Ride: bmw 1995 325i
Smile Bad starter/new one cranks but will not start???
Bought a new starter,put it in ,started up 3 times next time just the big CLICK!!Bench tested it after,same thing! Contacted the co. I bought it from. Sent this one back and they sent another! Put that one in,she cranks but will not start!! No power at fuel pump,no spark and no fuel flow!!
Hub is at wits end!!
He is ready to put this 95 325 i out to pasture!! Last year it gave him a run but turned out to be bad fuel!!
I did download the Bentley manual,did help a lot.
Maybe the bad starter fried the brain???
Any ideas??? Thank You!!Rose
Unread 07-18-2013, 12:02 PM   #2
DEATH2000
DEATH2000's Avatar
Title: Moderator
Rate My Car: 111 / 340
Your Ride: 1998 E36 328i sedan
You need to find out why you have no power at the fuel pump. Check all your fuses, and then checking the wiring to make sure its not frayed. You can pull the rear set up to acess the fuel pump.
VIEW MY E36 BLOG HERE
New to United Bimmer? Check out our Introductions and Greetings Section and introduce yourself today!
E36 Bentley Manual PDF download avilable HERE
Unread 07-19-2013, 05:58 PM   #3
rosesette
Thank you for the reply!! Can hear pump running but did not do a pressure check. Checked CPS, relays and fuses!!
Stumped,maybe the starter when it seized,new starter cranks but no turn over? Leaning towards a EWS issue?? Hit and miss !! LoL!!Probably would not hurt to bypass the EWS system? Car is a march 1995 325i .Has the silver label DME.
Last year a fuel issue!! Ran great for a year,then the starter issue!Yikes!
Thank You!!! Rose
Unread 07-24-2013, 06:19 PM   #4
DEATH2000
DEATH2000's Avatar
Title: Moderator
Have you tested the battery and alternator as well?
Unread 11-10-2013, 11:49 AM   #5
rosesette
Been awhile but we ended up doing a brain swap,switcthed to the red label,cut wire 66 and bridged 2 others. Hub also disconected the fuel line n fuse and connected fuel line pressure tool which cleaned the line and injectors She started!! Yea! Been running well but now a possible tran problem!! TCM?? A auto tran when in 3rd was sluggish. Old car!!95 325 i,but you sure cannot beat the ride!! Thanks for all the info!!
PLEASE Help My 325i wont start :( jespinoza37 BMW General Discussion 1 03-26-2012 08:18 AM
Gingrich campaign off to bad start, looks forward scooter    Latest News 0 05-18-2011 07:00 PM
1991 BMW 318i Wont start after overheating. Help! :( princetomtom E21, E30 5 04-27-2010 09:55 AM
Car Cranks but wont start? NewBIMMERfan85 7 Series (E23, E32, E38, E65, E66) 11 04-15-2007 11:07 PM
15 Things to do in Wal-Mart komodo Comedy Collection
4 10-05-2005 11:37 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
