Unread 04-01-2013, 07:30 PM   #1
javier
Your Ride: 1994 bmw 318is
18" wheels on my 1998 E36 328i .. will they fit?
I'm almost ready to retire. I'm gona bust out the gold chains, open shirt ( to show off my white chest hairs), and 2 tone Stacy's. I wana ride in style.
I'm restoring my BMW 1998 E36 328i. It currently has 15" wheels.
Need to know if the following wheels will fit my E36 :
Rim Brand: FACTORY OEM Part Numbers: Front 6779800 Rear 6779803
Rim Width: 7.5 FRONT 8.5 REAR
Section Width: 215 FRONT 245 REAR
Offset: 49 FRONT 52 REAR
Aspect Ratio: 40 FRONT 35 REAR
Number of Bolts: 5
Rim Diameter: 18
Bolt Pattern: 5x120
Tire Brand: Bridgestone
Hub Bore: 72.6
Has anyone tried this??
Thanks guys
Unread 04-11-2013, 07:26 PM   #2
I have a 98 328i and I currently have 18" wheels. I have 18x8" in the front and 18x8.5" in the rear. They will fit, however you will need to roll your fenders. I found under corning that the fender lip rubs aginst the tires when the body rolls. If your at stock ride hieght you will be fine, but if your lowered you will need to roll them.
E36 328i Auto 1998 - Starter does not turn over when hot. Grahamp E36 2 07-01-2009 05:25 PM
