Unread 02-07-2013, 07:17 PM   #1
Eskimo
Your Ride: '97-540i / '07 X3
Service code
Can anyone tell me what code: P1553 is? My X3 has a repair code on my scanner but I don't know how to translate it without a service manual. Please.
2007 x3 3.0
Unread 02-08-2013, 06:21 PM   #2
P1553 is the Vanos Solenoid. If you can, clear the code and if it comes back again replace the solenoid.
Unread 02-08-2013, 06:54 PM   #3
Eskimo
Service Code
Thanks Death2000-My mechanic said it was caused by not enough warm-up
in very cold weather (12-15degrees) or too heavy oil-a valve controlling the VANOS was apparently affected. My scanner is not programmed for European
cars. I reset the code and will keep an eye on it. Thanks again.
Eskimo
Unread 02-12-2013, 07:32 PM   #4
What oil are you using? The lifter and top end of the engine is the last to get oil as it has to be pumped up to the top on startup. The BMW LL01 (US) standard recomends Mobil 1 0w-40 or German Castrol 0w-30. Anything too thick and your going to have ticking from the lifters as they get oil starved. I run 0w-40 even in the winter.
BMW Inspection I & II Service DEATH2000 E36 0 03-26-2012 10:07 AM
Ran my code reader this morning before my appointment - 3 new codes billycuth E36 8 06-28-2005 07:41 PM
