Unread 11-13-2006, 10:33 PM   #1
B_w.
Rate My Car: 62 / 340
Your Ride: turbo e36
i really like my bilstein sport shocks with h&r sport springs but if i had to do it all over again i would go with a nice set of coil overs. probably from ground control.
Unread 11-14-2006, 01:28 AM   #2
Coil overs would be kool. I have Konis and there pretty decent.I like em.
Unread 11-14-2006, 10:04 AM   #3
I love my Bilstein Sports. I can't imagine what the Bilstein Race setup would be like though... :drool
Unread 11-15-2006, 09:01 AM   #4
Ground control coilover setup with all the supports, etc. Like rtab shimmy's. You would also need camber plates, but thats ok Man that thing would have ///Mazing handling, ok so that was corny lol.
Unread 11-15-2006, 11:11 PM   #5
B_w.
i wish i spent the extra coin and didd that
Unread 11-16-2006, 02:52 AM   #6
Turbodefrost
Turbodefrost's Avatar
Your Ride: 1996 328is
Send a message via AIM to Turbodefrost Send a message via MSN to Turbodefrost Send a message via Yahoo to Turbodefrost
yeah i think for the most part people who got shocks and springs wish they woul've just put in a little more money for some coilovers. I'm really happy with my Bilstein sport/ H&R race setup. but camber plates, adjustable control arms are a must. and yes you should definitely replace the RSM's FSM's, ltabs, rtabs and so on and so forth
Unread 11-16-2006, 11:42 AM   #7
Sorry to hijack we should get storamin back on here.
Unread 11-16-2006, 12:05 PM   #8
Where did he go? I miss him hating everyone that owned an automatic.
Unread 11-16-2006, 01:18 PM   #9
B_w.
i am pretty sure i can fill that role auto's suck fucking ass!!!
Unread 11-16-2006, 02:22 PM   #10
He was banned, i miss the rants and auto hating as well it always made for some good entertainment.
Unread 11-21-2006, 02:30 PM   #11
///M Power
Rate My Car: 26 / 340
Your Ride: 95 m3 turbo
coilovers + corner balance
Unread 11-22-2006, 09:28 PM   #12
B_w.
what do you mean by corner balance?
Unread 11-25-2006, 01:34 PM   #13
///M Power
Basically you can adjust your suspension ride height enough at each corner so that essentially each corner is acting as if it's holdign the same amount of weight. You want to get a perfect balance between all four corners. Some race shops near you should have the scales. Have them do it, or if you got a lot of time on your hands and feel liek havign some funw ith some friend go ahead anf borrow/rent them from them.
Think of it this way. There's no way all four corner of your car weigh the saem at each tire. So you put all four on the scales and find the weight at each corner. I've never doen this but you need to essentially take all the numbers and calculate out what weight should be added at each corner adn what weight should be removed at each corner to get them all to be the same. The catch is you never add or remove weight. Instead you hypothetically find how much weight must be removed/gained. Then you slightly adjust the ride height at the corespondign corners.
Each corner acts similar at it's caddy-corner (front left has same weight characteristics and rear right).
So let's say your front left and rear right need to pick up some weight and your frotn right and rear left need to lose some weight. Essentially (if i got this right in theory), So if you lower the ride height a hair on the front right or rear left, then there's less weight on both of those and more weight balanced onto the front left and rear right. It's hard to see in writing but it makes sense if you really think about it.
A good analogy someone told me long ago was imagine a giant box that four people of equal weight/muscle/height/build were carrying. Each person is hold a fourth of the weight. If the back left corner were to lower just a little bit, that would put more weight on the back right and front left corners. I was always a little confused as to why the back left corner never gained weight, btu im assuming it has a lot to do with the rigidity of the car. Thats why sometimes you see a car that could essentially drive on 3 wheels (albeit not well).
I don't have the exact science down and i've defintely never had personal experience with it (damn h&R/Bilstein), but as soon as I get coilovers it would be the first thing i'd do.
Unread 11-25-2006, 01:39 PM   #14
///M Power
I'm sure I missed/confused a few things there, but I googled this and I think it should help clarify things: http://www.scottgood.com/jsg/blog.ns...ks/SGOD-6B9PFW
Unread 11-25-2006, 02:16 PM   #15
devinwwu
Rate My Car: 49 / 340
thanks for explaining. I have coilovers on my e30 and couldn't be happier! Find out what the manufacturer recommends for your type of driving in terms of spring rates and add 50lbs to make it a little edgier. Mine is not too ridgid and handles like it is on friggin rails!
I am corner weighting mine as soon as i get a chance to see the difference between stock and m30 swap e30s as well as dial in my suspension.
UUC sachs suspension 94bmw325i Tire, Wheels And Suspension Forum 1 02-15-2006 08:12 PM
e36 suspension EuroStyle Vendor/Dealer Comments & Supporting Vendor Announcements 4 10-19-2005 01:47 AM
Suspension (Shocks & Joints) Replacement or Chassis Lube? delmarco E36 15 08-17-2005 12:15 PM
FK Automotive suspension DEATH2000 Tire, Wheels And Suspension Forum 3 06-26-2005 06:36 PM
poll: suspension or brakes? Spieluhr E36 40 05-11-2005 11:48 PM
