Unread 03-22-2006, 01:55 PM   #1
looks like the drain line was off from your battery, once you clean that stuff up, if I were you, I would undercoat the battery compartment
Unread 03-22-2006, 02:11 PM   #2
It may have splashed in from underneath. Have you driven through any big puddles?
Unread 03-22-2006, 02:14 PM   #3
Well i drive in the rain alot...but thats a huge design flaw if so. I havent driven through puddles big enough to submerge my rear arpon.
Unread 03-23-2006, 07:05 PM   #4
Originally Posted by Rooz
I'll take pics when my car is back into my hands
k thnx dude.
I sanded off any thick surface rust and wd-40'd the rest and wiped it clean. Cleaned the bolts for the battery tray and sparyed the area with undercoating. Only complaint is that its black, but what ever u cant see it. Now my only question is where did the water come from. And wheres that drain plug connect to.
Unread 04-03-2006, 01:42 PM   #5
mitch500
mitch500's Avatar
Your Ride: e30 325
trunk seal mine does it too just suck it out -with a shop vac and put a new trunk seal in
Unread 06-28-2006, 12:09 PM   #6
jeffrox
Your Ride: 1991 318is
The same thing happened to my 325 it was the trunk seal. To get rid of the water happening again i just drilled a hole through the bottom of it. It may not be the most conventional way of doing it but it worked.
Unread 06-28-2006, 12:37 PM   #7
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 131 / 340
i better go check my batt compartment!
i know the sunroof has a drain that comes out near there, somewhere behind the bumper. maybe its coming from there, maybe from the rear light assembly isnt sealer?
Unread 06-28-2006, 01:14 PM   #8
You guys need an E36 . . that way the water draining shorts out the tail lights instead of collecting at the battery
Unread 07-06-2006, 12:17 PM   #9
sbcBMW305v8
sbcBMW305v8's Avatar
Your Ride: 1987 BMW 325 with a chevy V8
same thing happened to me all you need to do is replace the trunk lid seal and everything should be fine
Unread 07-16-2006, 10:42 PM   #10
thnx. Im going down to the dealship after i pay off my current debt. Ill pick one of those up and a couple of other seals.
Unread 07-17-2006, 08:39 AM   #11
celsdogg
celsdogg's Avatar
i would also check that sunroof drain, heres a picture.
Unread 07-17-2006, 08:53 PM   #12
...ahhhhh Im gona go out and check that
Unread 08-23-2006, 04:43 AM   #13
Dr1ve4fun
Rate My Car: 237 / 340
Your Ride: 1985 325e
I occasionally get a little bit of water on the battery side since the left taillights leak everytime it rains..If it rains enough it can get over there too. Has anyelse had this problem? If so how did you fix it?
Unread 08-24-2006, 08:40 AM   #14
e30boarder
e30boarder's Avatar
Your Ride: e30
Send a message via AIM to e30boarder
i had a similar problem... it was filling up with water on the opposite side, my antena seal was bad. for dyrte i think u just need a new seal if its ur taillight thats leaking...
Unread 08-24-2006, 08:43 PM   #15
Dr1ve4fun
I was looking at it closer today and put a hose on the car to see where exactly its leaking..its where the taillight lense seal is for now i put a little bit of tape over it since i need paint anyways just til i can do something better
Engine Compartment Cleanliness Rob Detailing and Cleaning 0 03-17-2006 12:38 PM
water pump cabrit E36 2 02-28-2006 05:10 PM
I think my battery done for. What should I replace it with? delmarco E36 21 09-17-2005 11:20 AM
water leak damn another problem!!! defkon99 E36 45 09-02-2005 07:39 PM
My battery is dead Rooz E36 24 05-24-2005 11:30 PM
