Unread 03-21-2006, 10:59 PM   #1
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea Send a message via Skype™ to doughboyea
Your saying to spray the joint between the pulley and the assembly or the belt and pulley. If you mean the belt and pulley, isn't that a bad idea? I mean, do you really want that to be slippery?
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1999 BMW 328i E46 Dinan Stg. 1
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Unread 03-22-2006, 12:31 AM   #2
barney
barney's Avatar
Your Ride: 01 330Ci
Send a message via AIM to barney Send a message via MSN to barney
Right, you dont want get it on the belt, just on the stud/shaft that the tensioner pulley itself spins on. Ive had this happen on several of the vehicles i've owned. Had to remove it on one to get the oil worked into the tensioner bearing.
Unread 03-22-2006, 12:06 PM   #3
barney
barney's Avatar
Your Ride: 01 330Ci
I didnt want to steer you wrong so decided to see what it would take to actually remove mine. You will need metric allen wrenches and torque bits, at least i did. you can remove just the pulley too instead of the whole tensioner assy, might be cheaper if you can get just the pulley. You want to make sure which pulley is making the sound because there are some idler pulleys which could go bad also.
Unread 03-22-2006, 02:27 PM   #4
barney
barney's Avatar
Your Ride: 01 330Ci
then take the plastic center cover off the tensioner pulley. Then using the correct size allen wrench and a cheater bar, (unless you own the correct tool, which is pretty much the same thing) relieve the tension (try to tighten the allen bolt) remove the belt then remove the allen bolt from the pully and remove the pulley.
Unread 03-22-2006, 02:46 PM   #5
DAMN, Barney - I dig these DIYs while you wait...LOL Can't ask for a better than that. Cool Stuff!
Unread 07-15-2006, 07:54 PM   #6
doughboyea
doughboyea's Avatar
The sound is getting worse. Last friday I contacted my local dealer to find the pricing of the hydraulic pulley. This is what he, Rob, sent me. I'm not sure if I can follow it.... I don't think it's because I"m being really slow or what, check it out:
Originally Posted by HunterdonBMW
THE HYDRO UPGRADE IS $250.00
THE TENSIONER IS $71.00 FOR THE LOWER ASSYMBLE
THE UPPER IS JUST THE PULLEY PRICE IS
$38.50
ROB
I'm thinking that the hydraulic assembly is $250 plus the $38.50 for the pulley. If I am correct, is that a rip off?
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 09-12-2006, 08:28 PM   #7
doughboyea
doughboyea's Avatar
Well, it came to a point where I HAD to go to the dealer as I just had NO time to do anything to my car. The dealer said that the tensioner is getting close to the end, but that's not what was making that loud noise. It was the AC compressor. Aw Fuck. Great......
Since they were there at it, they changed the tensioner too (to the upgraded hydraulic one). Now, if anyone in the future cares to know, a re-manufactured AC compressor installed will run you $1300 and an installed tensioner will run you another $500-600. In the end, after tax and shit, I dished out $2072. What a fucking money pit I'm in with my first year E46. Fuck.
BMW should be paying me for thier guinie pig experiments.
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 09-12-2006, 09:23 PM   #8
Dough
ouch, they got you good
Considering Buying An E30?Upgrades?Differences? spiff E21, E30 30 04-14-2012 10:12 AM
I finished the engine swap htp.bmw E21, E30 7 06-21-2005 11:33 AM
Sound Card Issues komodo Geek Chat 9 05-18-2005 10:11 PM
2.5l Engine, 2.8l Cams, and more for Sale jrhaile Bmw Cars For Sale/Wanted 7 04-28-2005 08:54 AM
