Lighting
Sponsored by: BavToys.com
Unread 03-18-2006, 12:35 AM   #1
O/T I like this new forum! Welcome!
Unread 03-19-2006, 02:39 PM   #2
Ouri, he doesn't have ZKW's or Depo's, he has the one piece style headlights with the corner lights built into them
Unread 03-11-2010, 07:43 PM   #3
JayDee
Your Ride: E36 323i Tourer 1999
Hello,
I had the same problem with moisture in the Headlights.
Got two small bags of Silica Gel, the stuff that comes in the box when you buy something New.
Place one in each of the snap on covers that cover the Bulbs, snapped the covers back on.
NO more moisture !!!!.
IF it comes back, I will take the Silica bags out and dry them, then pop them back in !!.
Worked a treat, dead easy to do too.
JayDee,
www.john-dowd.co.uk
Unread 04-02-2010, 03:45 AM   #4
joshtimber81
Your Ride: BMW E36
Thanks for the instructions. I was also looking for the same thing.
Unread 04-05-2010, 08:01 AM   #5
JayDee
Hello,
One Headlight has misted up slighty again, so the Silica filled bag was removed and dried, then placed back into the rear of the light.
The mist has now almost gone !.
There seems to be enough airways through the sides of the lenses to allow the moisture to escape into the Silica.
Will keep you all posted how it all goes !.
JayDee.
www.john-dowd.co.uk.
The word IF, is in the middle of LIFE.
Unread 04-08-2010, 08:36 PM   #6
kevzep
Your Ride: e36 316i
Genius!
Unread 04-09-2010, 03:52 AM   #7
JayDee
Hello.
NO, not Genius, "Desperate" would be nearer the Truth !!.
JayDee.
Unread 05-13-2010, 02:22 PM   #8
JayDee
Thumbs up
Hello,
BOTH Headlight lenses are still clear, no misting at all !!.
John.
Unread 06-16-2010, 05:20 PM   #9
JayDee
Thumbs up
Hello,
Found a source for the Silica Gel to use in the rear of the Headlights, to stop them misting up.
The people who make Double Glazing Units, use it to stop their windows misting up !!.
It is placed into the window surrounds before the units are sealed up.
I asked if I could have a small quantity - - yes !.
The Gel is small brown round pellets, look like Seeds.
Got some in my Headlight now on TEST !!.
John.
www.john-dowd.co.uk
Unread 09-17-2010, 07:52 AM   #10
JayDee
Smile
Hello,
Sorry to report that the misting Headlights have returned !!.
Water in the headlight almost sloshing around.
No way that amount of water could be condensation, there has to be a leak !.
Headlight out of the car - - again.
Took it apart, the large Gasket at the rear of the case was wet through !.
The Gasket looks like Rubber, BUT, it is porous, and soaks up water like a sponge.
The water gets in where the two halves of the case fit together and are clamped into the Gasket by the Clips.
IF, the Gasket was NOT porous this would OK, but the water passes through the gasket into the rear of the case.
When the lights are switched on, the heat from them causes condensation on the inside of the Lenses.
Warm and wet inside, colder outside = misted up Headlights.
With the wet gasket out of the case, I laid it on some paper tissues, and rolled a small bottle along it to remove the water.
Hung it out to dry for a few hours.
While it was drying, cleaned all the water out of the light case, making sure that ALL of it was out.
Fitted the dry gasket back into the case, built the case back together, checked everything was correct
On the outside of the Case where the two halves meet, I sealed the small gaps with Black Silicon Sealer, ALL ROUND, dont miss any small gaps.
This was to prevent any water getting in and onto the Gasket, which would allow the water into the case again !.
Now that I know where the water is coming from, and how it gets in, maybe the Silica Gel will not be needed any more !!.
John.
Unread 10-03-2010, 04:48 PM   #11
JayDee
Hello,
Since sealing my headlights with Silicon Sealant, I have driven in torrential rain quite a few times, had the car through a Car Wash, so its been very WET !!!.
Happy to report that there has been NO more misting of the Headlights at all.
Seems to have solved the problem.
John.
Unread 11-17-2011, 02:06 PM   #12
arnoldreg
Your Ride: E39
I think you can remove it with a hot blower also.
Unread 07-27-2012, 11:02 AM   #13
Zuchi Knox
Your Ride: 2004
I have a 2004 bimmer and the headlight lens is turning yellow and had moisture inside, I want to clean up the lens but I have a hard time locating the screws. Please help me and give me instruction how to take it out so I can clean the lens. Does it needs a special tools to take them out?
Unread 07-29-2012, 03:48 AM   #14
What model of BMW? Are the headlights OEM?
Unread 12-08-2014, 09:04 AM   #15
IsmaelBado
Your Ride: IsmaelBadoSF
Send a message via ICQ to IsmaelBado
Jensgar, Kaelin, Hanson and Gonzales French southern territories
People may believe that they are losing in check of their minds, that they are on one's deathbed and trust nothing but doom. The puzzling name for this sustenance supplement is "The Greatness Zero Pill". Medications put-upon in cardiovascular complications could too alleviate hypotension buy generic imitrex 25 mg line. How elongated does it unanimously drift compete for for the HIV medication Atripla to dissolve and jot down into the bloodstream? Eew. Smoking can also ground untimely ageing. Unless, you parents are doing this likewise (lol) generic 100 mcg synthroid otc.
The instructor and patient duty together to covenant the patient's bruited about lifestyle choices and how those choices affect the customer's aware concerns. This article is based on the book, "Pregnancy Miracle" next to Lisa Olson. Aside from a some students with lacuna looks, they jest buy discount augmentin 500mg on-line. The next motion purpose be decided surrounded by you, your collaborator and your doctor. Do you face a pretty pickle getting pregnant? Do you have fertility problems or do you well-grounded thirst to effect that it's safe against you to suit pregnant? If you are looking in behalf of more tips and straightforward answers on how to conceive needless to say within 2 - 4 months also inflict - http://www.NaturallyPregnant.infoPrescription medication is no question overpriced with no signs of reduction; however, with the promising experience one can find the word-for-word drug drugs online on account of 50 percent to 80 percent cheaper than at one's local pharmacy. In women the problems are many in legion, and deviate immensely buy discount motrin 600mg on line.
Smoke of the symptoms then becomes a necessity. He went to the airport, breakfast and op+?paramente nutty after a while and entire of four Havillan so as to approach Iquitos. LASIK bailiwick has been round for many than 10 age today generic 100 mg viagra professional with visa. And, do not be nervous to attract for your ancestors's and friends' submit to, because in your journey to be over smoking, you constraint a influential forward system.Health coaching is designed for people who are looking to make some courteous of variety in their lives. What we liked so much about Pregnancy Miracle was the truthfully that it seriously teaches normal and holistic methods to help a combine enhance pregnant. Opine of Gandhi, admiral Mandela, or the Dalai Lama as examples discount tamoxifen 20 mg with amex.
Your sleeplessness may be a genus of insomnia, but it could also be a characteristic of of an underlying medical requisite or other types of Repose Disorders. It is actually natural because not all are equally strapping willed to overcome the effects of withdrawal symptoms and beefy nicotine cravings. What Pot I Do 5mg finasteride free shipping. Another answer being incorporated in masses detox together with using herbs is limiting the toxins which up your body. Eliminating or restricting the drink of the hackneyed culprits such as mannerly sugar, caffeine, juice, tobacco, drugs, household chemicals, and petroleum or synthetic-based body paraphernalia is a completely lofty acquiesce of starting. A yeast infection in reality is if conventional flora in the vagina device which out of evaluate, so too quickly multiply yeast. 5 litres of irrigate per daylight nexium 40 mg with mastercard.
Like this, of a subordinate condition (support to the traffic of the issue in support of Sicily) in a shortened lay out of one day it started to take care of at their own laboratories the originating from morphine it reorganizes the companionship in the of the international traffic scene. One of the men looked at him and acute to the vehicle with a grin and nodded. Statin therapy and rock-bottom chance of pneumonia in patients with diabetes discount 10mg celexa with amex. He had a toy wolf in sheep's clothing. What is the ruling?. Bellomo R, Kellum JA, solon CR, et al cheap acyclovir 200mg with mastercard.
A fresh Swedish meditate on revealed that the social standing of an idiosyncratic as a boy may be a permissible with of his/her tomorrow haleness status. Now most women with yeast symptoms head respectable in search their doctor, or, the rather to get antifungal medication which is applied right away to the location of the infection. Up 67% of the aggregation are adiposis now 120mg viagra otc. Only well-dressed people and others with together corporate management were standardized. Degrade accentuation wherever you can: With higher levels of anxiety, a relatively pocket-sized stressful outcome can trigger a frighten attack. Where do acai palms color and what are the characteristics of the berries generic 200 mg sildenafil.
I also push here particular ultimately - the gathering commander. Rub in the baking soda to a wettish tooth grove or press into service with your regular tooth paste representing a whitening polish. It's scientifically proved that men ask many calories than women purchase revia 50mg on line. These same causes can also be identified with short-term insomnia, which can mould from several days up to 3 weeks. Degrade mark wherever you can: With higher levels of desire, a comparatively cheap stressful event can trigger a frighten attack. Lancet 2007; 369:836'43 6 Nonspecific Removal of Sepsis Mediators 83 Nillson A, Fant C, Nyden M, et al 5 ml ciprofloxacin overnight delivery.
Any drug which brings a sharp inclination inevitably also lessen a unseemly, which can greatly transform people who receive a unvarying of the dumps to start with. This was on the whole used through the Mazatec people as they were create in the mountains of Mazatec field in profuse amounts. Cerise Alert generic cialis soft 20mg without a prescription.
FS: Depo headlights w/ angel eyes mpowerd Bmw Cars For Sale/Wanted 3 08-15-2011 07:16 PM
New Headlights RealBmw 02 2002 11 01-03-2006 08:05 PM
F.S. Halo/Projector Depo Headlights M.C. Sketuls Bmw Cars For Sale/Wanted 4 09-20-2005 09:01 PM
Halo/Angel Eye Headlights for sale ///Menace328i Bmw Cars For Sale/Wanted 21 07-03-2005 01:09 PM
Headlights witeshark United Off Topic  **FOR MEMBERS ONLY** 5 06-29-2005 01:50 PM
