Unread 03-17-2006, 09:58 PM   #1
humm.. ur car is an M?
Unread 03-17-2006, 10:38 PM   #2
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
Much more responsive with a kick! ,much smoother idle, and thats with 5 month old plugs.
i actually just bought some fresh plugs im goin to drop in, which should improve it somewhat, but overall, definitely worth the money.
Unread 03-31-2009, 08:54 AM   #3
C Sean Watts
Name: C Sean Watts
Your Ride: 1997 328is and others
I see this is an old-ish thread.
I'm ordering some for my '97. The car runs well as it is but I have used MSD and Jacob's coils on other cars and the improvement from coils alone was always worth it in long run.
I'll be posting before and after results....
BTW, DOES ANYONE KNOW WHO MANUFACTURES THESE? BAV isn't sharing too much..
Unread 05-08-2009, 07:35 PM   #4
C Sean Watts
Name: C Sean Watts
UPDATE: I got them and measured the resistance of the primary sides on all coils. All are in the factory range 0.4 to 0.8 Ohm. I installed them...I changed NOTHING but the coils.
1. Slightly quicker start up warm and cold.
2. Idle is about the same. Idle was smooth before the change so I'm not surprised.
3. BIG improvement in acceleration, felt and measured. I went to a known 1800 foot marked area with little traffic. Started from a stop and WOT to the end. With stock coils = 0.40 seconds slower.
4. I'll update with mileage differences in a few tank fulls.
Unread 05-08-2009, 10:44 PM   #5
scooter
scooter's Avatar
Rate My Car: 296 / 340
Your Ride: 99m3
its more new vs old thing, the coils add nothing much if any at all there have been a number of tests that showed without a doubt that "H.O/performance" coils showed zero gains.
Unread 05-10-2009, 11:23 AM   #6
C Sean Watts
Name: C Sean Watts
Disclosure: I am not affiliated in any way with the company making or selling the parts I use, test or describe.
What we do know about flyback transformers, or LOPT, is they do not "get old and wear out" without some kind of quantifiable failure. Mechanical failure in them like a break or short in one of the windings do cause them to fail. In an OBDII car (at least according to the BMW FSM) will cause a MIL/CEL. I had neither case. The original coils also measured within factory specs (primary side resistance.) We also know that potential (voltage) makes the spark happen. But, it's current (amps) that light the fuel. Too much of either and NEITHER will happen. Since I did not change primary input, the only way to effect secondary output is to change the coils, themselves.
My experience over 20+ years of street and track - parts and service has included using Jacob's Electronics systems, Accel and MSD systems. The results all varied as much as the engines they were put on. The ONLY time I measure a zero gain was when an electronic ignition module happened to fail at the time we were testing. The change I described was carefully tested, measured and repeated.
Anyone interested in this subject, I refer you to the book by Dr. Christopher Jacobs, Performance Ignition Systems published by HP books #HP1306.
About 19 years ago, I had one of his first edition books on the same subject. It clearly takes electrical engineering theory and explains it in practical terms, as used in the real world.
Pics from Bav. Auto Show & Shine EnvyM3 Video and other Multimedia 12 10-17-2005 10:14 AM
Something New At Premium Auto Care Dwayne@PremiumAutoCare Detailing and Cleaning 1 09-19-2005 11:55 AM
