Unread 12-18-2012, 03:06 AM   #1
kevy711
Your Ride: 1994 318 is
Question code reader for mechaniv
Hi, I have 1994 318is and have searched everywhere for the adapter to read the codes and can't find it. Not the one on passenger side of engine,(dealers plug-in) but one for mechanic. would appreciate any cluesor maybe its the inbetween year that does not have one. thank you
Unread 12-18-2012, 03:49 PM   #2
kevy711
I need to find the port to plug-into so i can read the codes I don't know the name of it
Unread 06-20-2013, 06:11 AM   #3
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
The round 20 pin BMW diagnostic port is the only one you can access on your car. OBD2 ports (the 16 pin D shaped ones normally found under the dash on the driver's side) were not fitted until MY2000. Your best option would be to install some diagnostic software on a laptop and get an ADS/OBD interface from someone like http://interfaces4beemers.com/ , which will allow you to read codes from all modules in your car. If you just want to check and clear engine-related codes, get a Peake R5/FCX3 tool.
For US cars, you can use the stomp test to read the diagnostic codes - you can find instructions here http://www.pelicanparts.com/BMW/tech...de_Reading.htm .
Unread 06-20-2013, 01:41 PM   #4
kevy711
Thank you very much for your reply. Had finally figured it out.
Fault code reader recommendations? Victor520 BMW General Discussion 0 09-12-2012 04:39 AM
Radio Code mrkbik E36 16 03-13-2011 09:48 PM
Stumped by error code joeyp770 BMW OEM Parts Department DIY's & FAQ's 5 02-09-2010 09:05 AM
Ran my code reader this morning before my appointment - 3 new codes billycuth E36 8 06-28-2005 07:41 PM
Obd II Code Reader Spieluhr BMW OEM Parts Department DIY's & FAQ's 2 06-01-2005 01:22 AM
