Unread 12-14-2012, 11:04 AM   #1
Britar
Your Ride: 1993 325is
Clutch Pedal randomly falling to the floor
Good Morning,
I have a 93 325is.
I have about an hour commute each way, 55 miles.
Last week I noticed that when I come out in the morning to head into the office the clutch pedal is down about half its travel to the floor. If I pull it out and pump it slightly (pump in the slack area) it firms back up and isn't an issue. Especially on a Monday after it sat for a day or two.
Then this week a couple times after I'd been driving for 45 minutes or so on the highway with no clutch activity when I went to down shift the pedal was literally on the floor. I could get my foot under and pull it back and it would firm up with a gental pump <that's just funny/>.
Given that my tranny seems to act, release, and shift without other issue I'm thinking this is clutch slave related.
What do you all think?
Thank you for your help.
Brian
Houston, TX
'93 325is E36
Unread 12-14-2012, 11:50 AM   #2
Britar
From another forum, appears to be the master cylinder.
http://forums.bimmerforums.com/forum....php?t=1698450
Would still welcome any tips, advice on replacing.
Brian
Unread 12-15-2012, 08:54 AM   #3
I think you've diagnosed it right. Also, as I think the clutch hydraulics are integrated with the brake hydraulics, check the level of your brake fluid and check for any leaks in the system.
Unread 12-15-2012, 09:05 AM   #4
Sounds like your slave cylinder. Check for leaks under your vehicle. Dropping to the floor usually indicate a massive drop in pressure.
E36 Clutch Replacement DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 24 10-01-2012 12:18 PM
Just installed New Clutch PP & TB, Pedal goes to the FLOOR! STROKER E36 10 05-25-2007 12:06 PM
clutch pedal roage E21, E30 2 05-02-2007 12:58 PM
FAQ: How the clutch operates Dudesky BMW OEM Parts Department DIY's & FAQ's 10 07-09-2006 11:25 AM
Spongy? clutch pedal Dudesky E36 3 11-28-2005 06:37 PM
