Unread 07-06-2006, 02:11 AM   #1
Martin Long
Your Ride: BMW E36 M3 1994 3ltr.
Just a simple point, I don't know much about this, however once you install the chip you will need to earth the ECU case when you first start the engine. That is if you plug in the unit prior to fitting it back in it's hole, ground the case against the body whilst a second person starts the engine. Worth a try!!!!!
Do I Need to Replace DME Chip ?? singring E36 1 12-17-2005 09:54 AM
Racing Chip mammajamma E36 5 11-24-2005 01:25 AM
ordered tms chip today! devinwwu E12, E28, E34, E39, E60 12 06-27-2005 12:03 AM
Conforti Chip mrkbik E36 9 06-23-2005 07:39 AM
