Unread 11-30-2012, 09:53 PM   #1
jeff86h
Your Ride: 2004 530I
Help - Advice Needed! Steering
Hi all. First post on the forum.
I took my vehicle (530I 2004 w/82,000 miles) into the dealership to get the control arm replaced because the bushing was wearing away and it had a very slight pull to the left. With the car jacked up it had noticeable movement in the driver side wheel (about .25 of an inch). The next day i received a call saying they replaced the control arm, but now the steering is acting strange and they need to run a diagnostic and possibly recalibrate. A few hours later my service advisor called back and prefaced the conversation by stating he has terrible news - i need to replace my steering rack and my active power steering control module. Total cost $6,000.
Before i took my car in i had no knowledge of either of these going out. No leaks, no noise, no steering issues (except for the slight pull which i believe was caused by the worn control arm). Also, i had my car in the dealership for brakes less than a month ago. You think they would of said something if they noticed anything.
The car has been in a wreck. What they are saying is that sometime a wreck will reverse the polarity of the active steering and fry the module. Is this true? Even if it is why would my steering be fine until the dealership serviced it?
I haven't drove the car since i dropped it off, but what they are saying is that the steering feels loose and will suddenly jerk to one side.
I'm new to BMWs so, any advice would be very much appreciated.
Thanks.
Jeff
Unread 11-30-2012, 10:22 PM   #2
jeff86h
To clarify the wreck mentioned above - The car was in a front end collusion and repaired a few years ago.
Unread 12-02-2012, 01:42 AM   #3
I think thats complete bull shit on the dealerships part. Go get a second opinion. I have never heard that claim before. Odds are the pull is from worn out tie rod ends, or your alignement is off. If the pull is only during braking then you have a sticking brake caliper. Its a 2004, not a 2013, so its not as advanced as they claim. My friend as an 04 320i and I did his power steering pump swap.
Also im hoping you got a PPI and did a VIN check before purchasing the car so you would know the history. Its not the end of the world if the car has been in a wreck, but its important to know ahead of time. Specially if bought from a dealer.
BMW Heated Steering Wheel Retrofit Complete Pictorial DIY! delmarco BMW OEM Parts Department DIY's & FAQ's 5 12-09-2014 01:03 PM
BMW 330i-Power Steering Pump-Defective Bearing soidog E46 10 11-27-2011 09:18 PM
Advice needed please pink craven BMW General Discussion 0 06-22-2010 01:30 PM
Steering Controls Help Needed Mack033 E46 2 04-05-2007 08:56 PM
HELP! Advice On Shocks/Springs set Needed. See Pictures. Are These Good? delmarco E36 6 08-24-2005 09:34 PM
