Unread 02-18-2007, 02:05 PM   #1
BeRzErKaS
Your Ride: 330 Vert, boosted e36 325is
Send a message via ICQ to BeRzErKaS
Awesome write-up, Dudesky!
I was able to grab my CT results in about 25mins thanks to this procedure.
Although the numbers confirmed my worst suspicions ( ), the DIY was very helpful.
BMW 3 Series - "Consistency of Purpose...Excellence of Execution."
ERT Supercharged E36 325is - Zeitronix, SAFCII, Alpine, Autotek, Orion, Tinted, Smoked, Trackpiped and so much more...
Drop Top E46 330cic - Tints, clears, Remus Exhaust, ///M-Tech Wheels
Unread 02-18-2007, 03:07 PM   #2
Aw dude, sorry to hear Good to see you around tho!
Unread 03-03-2007, 11:37 AM   #3
Boxer19
Boxer19's Avatar
Your Ride: 2001 525i
Great write-up. Glad you mentioned the camera, I am looking for one for close ups.
Ever stop to think and forget to start again
Unread 03-03-2007, 03:11 PM   #4
Funny this thread resurfaced again today. I finally got around to replacing my valve cover gaskets this morning. Fairly easy job, but you have to be careful removing the cover off the wirebox that houses the coil pack wiring. It just snaps off, but I broke a few clips trying to remove it. And if you're following the Pelican Parts writeup for this job, they are incorrect- there are only 14 fasteners that hold down the valve cover, not 15 . . had me going nuts trying to find the last one
Unread 03-03-2007, 03:31 PM   #5
I've seen that also in some of Pelican parts DIYs - mis prints - I try to use realoems' exploded views they give a decent perspective on most.
Unread 12-06-2007, 04:25 PM   #6
bigtom21485
Your Ride: 99 328iC
since you drain the fuel before the test, how many cranks should it take to refill the fuel system before it actually starts the engine? (99 e36 2.8 w/82000mi)
Unread 12-06-2007, 04:49 PM   #7
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 255 / 340
Your Ride: 1997 328i
Hey! Dudesky! Talk about perfect timing! I just ordered spark plugs & a new valve cover gasket set, & I'm getting ready to do this job next week!!!
GREAT DIY!!!
johnnybayonne,
Unread 04-07-2009, 04:26 AM   #8
jarda
Your Ride: e36 318iS coupe
I can't see pictures - files.unitedbimmer.com doesn't work - any chance of fixing it?
Unread 05-15-2009, 08:49 AM   #9
barnutz
Your Ride: 98 328
Pictures?
Pictures are gone?
Unread 08-26-2010, 03:55 AM   #10
clarkperez2334
Title: Read Only Club
Your Ride: 1995 Nissan
Impressive one! Thank You!
Spark plug removal, replacing, and maintaining is not as easy as what you think! It takes a lot of effort and time. I already searched and read a lot of forums discussing about replacing spark plug but I found this post the most comprehensive with clear visuals and demonstration! Thanks for the effort... you did a great job!
Unread 09-08-2010, 08:43 AM   #11
DSP543GP
Your Ride: 1993 320i
Hi Guys!!!
CAn someone explain to me how to set the click torque wrench, I get confused with the digits setting. On the handle there's plenty of digits. I want to set it to correct specs for the Valve cover gasket and for the spark plugs. Sorry I'm new in DIY. Please help
BMW e36 320i
E46 Light Alloy Wheels
Everything standard and original
Unread 10-14-2010, 09:12 PM   #12
krislou80
Your Ride: 2009 BMW 323i
Great DIY!!! I have problem in my spark plug it fires off. so i order some igniter to fire on. any suggestions?
Unread 10-18-2010, 10:22 PM   #13
amath80
Your Ride: 2006 BMW
When it comes to your car's ignition system, timing is crucial. With correct timing, the spark plugs fire off simultaneously and electrical sparks are supplied to the engine cylinders at the right moment.the spark plugs can't do everything on their own. They still need an igniter to bring your car's engine to life. Without this simple device, the spark plugs won't function properly.
Car is down Rooz E36 121 01-28-2010 04:15 AM
Compression test Dudesky E36 4 01-21-2006 08:24 PM
