Unread 01-17-2006, 09:21 PM   #1
If your pads are down to metal or near it, I'ld park it until you get paid to fix it. Regardless of how "light" you apply them they still rotate so many times per feet and you're literally driving grinders not brakes. The excess heat affects: bearings, wheel seals, brake lines, calipers & brake fluid... and if it gets REALLY HOT you're risking alot more - like safety. It's a little hassle to avoid major problems.
Unread 01-17-2006, 10:20 PM   #2
I'm pretty sure you'll need new rotors anyway, IIRC BMW rotors are not supposed to be resurfaced.
Unread 01-17-2006, 11:51 PM   #3
Storamin
Storamin's Avatar
Title: Road Kill
You may not NEED to replace your rotors. You can probaly have them turned if there is enough rotor thickness. However, with metal on metal contact I would replace the rotor.
Has your Brake Pad light come on yet? If it hasn't, I would drive the car as normal. You do have 3 other wheels braking (hopefully).
As c1apton said, you're just putting extra stress on everything else now.
Unread 01-18-2006, 05:26 AM   #4
Wow. If you're getting metal grinding and the brake light hasn't come on yet, I'd say there's something wrong with your pad sensors
Unread 01-18-2006, 02:37 PM   #5
^could the pads be okay but the rotors have worn too thin?
Unread 01-18-2006, 09:44 PM   #6
RealBmw 02
Title: GRIP > DRIFT
Rate My Car: 76 / 340
Send a message via AIM to RealBmw 02
^^ that wouldn't cause metal to metal contact. Rotors are printed with a min. thickness on them and shops who do brake jobs will use a micrometer to check the thickness before and after they turn them.
1970 BMW 2002
Driven by skill, not money
"Real BMW's have round tail lights"
Unread 01-19-2006, 01:10 PM   #7
Montizzle 325i
Your Ride: 1998 dakar ///M3 sedan 5-spd
thx guys. yeah i checked the rotors and those are all good not warped or nething because im experiencing no shaking or shimmying when i come to a stop. the prob is pads which is an easy fix i will be doing tomorrow.
front brakes brien4787 E36 4 02-06-2006 11:33 PM
Big brakes and R1's...... Timboy BMW General Discussion 9 12-02-2005 05:13 PM
mmmm brakes bitcore E36 31 11-16-2005 09:24 PM
Brakes have arrived! Spieluhr E36 25 08-16-2005 02:23 AM
poll: suspension or brakes? Spieluhr E36 40 05-11-2005 11:48 PM
