Unread 11-13-2012, 12:16 PM   #1
bazzcork
Your Ride: bmw 318 is
e36 318is fuel gauge problem
im having a problem with my fuel gauge , everything else is working but the fuel gauge doesent work and the fuel gauge warning light doesent work. ive checked the gauge float and the wiring on it and connections . is there a separate fuse for the fuel gauge? will i need a new cluster?
Unread 11-14-2012, 04:56 PM   #2
You could be having a problem with the gauge that was not uncommon when E36s were new, it's a bit odd that it's happening with a car with some years on it. There was some sort of electrical problem, and the solution for me was given by the dealer's service shop, pull fuse #30 or #11 (I'm not sure on those numbers) and leave out for 10 minutes. Reinsert. Cross fingers and see if that solves it.
There have been postings on this, do a search for further discussion.
Unread 12-03-2012, 03:38 PM   #3
bazzcork
thanks , that hasent worked ill try it again though . i might have to replace the unit in the tank .
Unread 12-03-2012, 05:19 PM   #4
It could be the unit, but before going to that trouble and expense, double check the fuses that relate to the sending unit and the fuel gauge, I think they are #30 and #11 but I'm not positive. There are at least two involved.
BMW E34 524 TD Fuel gauge slow :( Mamij E12, E28, E34, E39, E60 1 07-28-2011 09:32 PM
fuel gauge reading empty when tank full magners22 E36 4 01-31-2011 04:27 PM
DIY: E36 Fuel Filter Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 11 12-12-2010 03:16 AM
