Unread 12-30-2005, 12:14 PM   #1
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
Windshield Wiper issues
So I am driving on the PA turnpike last night in a nice driving rain, when all of a sudden, my wipers start acting funny. At first, the start doing a pattern of 3 quick wipes, then stay off for a few seconds then another 3 quick wipes. Then they stop completely for a couple minutes... Meanwhile, I am doing like 75-80 trying to keep up with traffic () with no windshield wipers and its starting to get hard to see (my rain X hasn't ben re-applied in a while)... So then I make it to the toll booth and they kick on again, working fine for a little, then doing the same 3 quick swipe/off pattern again... Then they stop again for a long time. I get gasoline and when I turn the car back on, they work fine, but then eventually stop again before I get home...
My question is, is it the motor or the computer? When they would go off, moving the position of the steering wheel stick did not affect them. They still did not work.
Any suggestions, or others that have experienced this?
I am worth $2,022,318 on HumanForSale.com
Unread 12-30-2005, 12:41 PM   #2
Either the wiper relay is loose or going bad. Sometimes when they're going bad - they heat up and lose contact, when they cool off works fine again. Check the wiper relay & fuses.
Unread 12-30-2005, 01:39 PM   #3
billycuth
billycuth's Avatar
you know, my car has been telling me to check the coolant lever for some time now... but when I check it (cold) it is at the fill line.... could the engine temp be affecting it? My guages never leave the straight up position after the car warms up though...
Unread 12-30-2005, 01:45 PM   #4
Your coolant level wouldn't have anything to do w/wipers. The check coolant issue is probably a bad or sticky sensor in radiator. (they're notorious for that) but the wiper issue sounds like it's an electrical/connection problem. I'ld check fuses & relay
Unread 12-30-2005, 02:06 PM   #5
billycuth
billycuth's Avatar
will do... thanks...
if its the relay, anyone know of a good place to pick one up at?
Unread 10-09-2008, 11:16 AM   #6
kandasx301
Your Ride: 1992 325i BMW
hey guys i have a similar problem my wipers only work on high and non of the other settings i checked the relays and I`m 90 % sure its not them i dont know were to check for the chip any ideas would be appreciated
Bosch Wiper Blades Timboy E36 10 12-30-2005 03:17 PM
Weird issues.... billycuth E36 11 12-05-2005 12:25 PM
Door lock issues kestrel325is E36 9 10-01-2005 09:17 AM
im having hardware issues... e30boarder Geek Chat 15 08-08-2005 03:09 PM
Help! tranny issues jrhaile E36 1 05-31-2005 08:34 PM
