Unread 12-14-2005, 01:10 PM   #1
Timboy
Calling ALL 'Codebreakers'
Here in the state of Georgia we are required to have our cars tested for emissions every year. Yesterday my car failed the test.
Never had this happen before. The test detected an onboard diagnostic code of P0128..... Anyone know if this is a failure of the O2 sensor????
The car is getting it's 60,000 mile checkup on Friday anyway. I was just curious as to what that code meant.
Who U are, U are Forever.....
Oh I collect stamps alright, I keep them in my Passport!!!
I am nobody----nobody's perfect----therefore, I am perfect!
I am a product of curiosity!
Unread 12-14-2005, 02:21 PM   #2
P0128 is Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
Now I personally don't know much about the coolant system inside a car, but hopefully this will tip off someone who does. Maybe the thermostat is broken that reads the temp of the coolant? Is there any kind of heater in there that could be malfunctioning?
Unfortunately it doesn't sound as easy as an O2 sensor.
Unread 12-14-2005, 08:17 PM   #3
whys this in teh e46 area?
Unread 12-14-2005, 08:22 PM   #4
^2001 330ci
Unread 12-14-2005, 08:27 PM   #5
Was the car up to normal operating temp? If they tested while cold or still "warming up" they'll get a "rich" reading. Sounds like "operator error" if the above is the case. Does your temp guage read "dead center" or near that point? If not, especially on the low side, car will run rich and not pass emissions.
Unread 12-14-2005, 08:27 PM   #6
oh.....for some odd reason i thought Komodo wrote that.
my bad
Unread 12-14-2005, 11:05 PM   #7
Timboy
Car had been running for about an hour, temp hand was dead center, and there has never been a heat/heater or coolant problem.....
Unread 12-15-2005, 05:07 AM   #8
Ok, then try this before any mechanicals. Get your self a small bottle of STP gas treatment and put in tank & fill tank up. Also clean you MAF and make sure air filter is clean. Most inspection places are questionable and can easily be at fault. Other options: get a second opinion from another inspection place or at a dealer. Just trying to save you $$$ before someone(inspection place) gives you advice via their asses. They tend to see $$$ when a BMW rolls in.
Unread 12-15-2005, 05:09 PM   #9
Timboy
Thanks C1apton.............
Unread 12-19-2005, 05:34 PM   #10
Antiburn
Antiburn's Avatar
Rate My Car: 193 / 340
Thermostats on BMW can throw faults. BMW's are designed in such a way that your thermostat helps regulate your emissions output. If its engines a little hotter then usual due to your thermostat not opening correctly your Nox emissions will rise which will cause your car to fail, like it did. Only way around it is to replaced your thermostat, I believe they go for 115$ or so. Its a ridicilously easy job so if you want to do it yourself you just need a few tools.
Calling all sig makers 94bmw325i Video and other Multimedia 0 03-19-2006 10:56 PM
Answering Machine Messages komodo Comedy Collection
11 10-27-2005 03:57 PM
Calling all Artists! Cellardoor United Off Topic  **FOR MEMBERS ONLY** 4 08-16-2005 01:19 AM
