Unread 09-21-2012, 03:44 PM   #1
audio8
Your Ride: 1998 525
1998 528i electrical problem?
I have a 98 528i and i seem to have an electrical issue. The problem is that several tings do not work and i think they could be related to a common problem. here is a list of what does not work. Radio, cruise control, windshield washer. Here are other symptoms. The radio will not even light up. The turn signals will not flash on the inside but if you turn the switch off and turn on the emergency flashers they will flash inside till you turn the key on. Then they no longer flash inside but continue to flash outside when the switch is on. I think none of the computerized diagnostics or indicator lights work correctly either. I do however believe all of the gauges are working correctly.
Air bag light stays on. If you have the door open when you start the car it continues to show the door open. the one question i have is do these things run off of a secondary electrical circuit than comes on after a few second of turning the switch on? I also realize that most of the things are probably not related but i didnt want to leave anything out for fear that something might be a clue. The car had these problems when i bought it. I have no idea of the history of the car so any help at all would be appreciated.
Unread 09-21-2012, 10:25 PM   #2
The electrical issues may be all wiring related. You need to find the things that are not working and check to see if they have power. If not, you need to start tracing the wires back to the source to see if their are any shorts, or bad ground connections.
Unread 12-10-2012, 10:10 PM   #3
BILLYBONG
Your Ride: 1998 E39 528
I had exactly the same problems as you. It's the ignition switch, 25 from the stealers and 25mins fitting it all your problems will be gone
1998 528i sunroof repair bpress365 5-Series 1 04-24-2012 02:27 PM
1997 528i starting problem jake carona Introductions and Greetings 1 04-21-2012 11:53 AM
E38 740i 1998 gearbox problem max79 7 Series (E23, E32, E38, E65, E66) 0 12-05-2008 12:30 AM
Electrical lighting problem...HELP Originalblend E36 1 06-01-2007 12:18 PM
