Unread 04-16-2005, 01:16 PM   #1
Torque
Torque's Avatar
Title: Lawl.
Your Ride: '00 Impreza
Send a message via AIM to Torque
E34: What will break ?
Courtesy of www.bmwe34.net:
1. Self locking bolts on cam oil spray bar. Look for worn camshaft lobes from this.
2. Hood & trunk gas lifts.
3. Front suspension: tie rod ends, ball Joints, possibly struts and bearings. Thrust arm bushings.
4. Sway bar links and bushings. Rear differential mount and rear subframe bushings.
5. Fan clutch on water pump.
6. Brake rotors, pads, sensors, timing belt and tensioner (M20), brake or clutch switch.
7. Exhaust components, usually muffler. O2 sensor.
8. Heater control valve, Fan speed control whether sword or resistor pack. A/C compressor.
9. Differential speed sensor.
10. Clutch, Driveshaft ujoints center bearing guibos.
11. Radiator and hoses. Thermostat.Water pump
12. Doors restraint (the metal bar that stops the door from opening too far) is attached to the very thin metal of the door frame and is starting to fatigue and crack.
13. Gauge cluster, usually capacitors repair for 5.00in parts or purchase 750.00 rebuilt unit.
14. Steering box, excessive play on center, sometimes just an adjustment.
15. Light control module (LKM) repair or replace.
16. Seat cables modified. Arm rest repair. Door panels above armrest coming unglued.Sunroof drains plugging and sunroof seals out of aligment.
17. Wheel bearings front and rear, usually front first. Sealed unit you must buy the entire hub. Cv boots on rear axles.
18. Oil canister (oil filter housing) valve is failing. This is BMW mistake. Canister needs to be changed (M30 engine only).
19. Fuel pump relay and main relay.
20. Glove box latch.
21. Excessive play in shifter handle on automatic. Adjustment.
22. Automatic transmission depending on maintenance.
23. Timing chain tensioner.
24. Fuel pump.
25. Occasionaly an oil pump. Not that common.
26. Occasionaly a headgasket. Common on M30 engine with the coolant that had not been changed every 2 years.
27. After 400k miles, you should change your engine :-)
Unread 04-16-2005, 10:59 PM   #2
528man
great find
1997 528i
Unread 04-18-2005, 09:51 PM   #3
munichman
Send a message via MSN to munichman
and nikasil V8s...
Unread 05-10-2005, 04:01 AM   #4
cainchapman
cainchapman's Avatar
Rate My Car: 127 / 340
Your Ride: 1995 540LE
Nikasil is only a problem for you guys in the US. We never had a problem with our Nikasil blocks due to our fuel! Nothing wrong with my M60
Unread 05-14-2005, 03:51 PM   #5
4themasses
Is that all......for a minute I was worried....
Move Over for the Executive X-press
89 525i - BAV AUTO Springs, 17" Borbet, X-drilled rotors, Racing Dynamics Cat Back
98 328is - Dinan Carbon Fiber CAI, 18" HP rims, many mods sitting in basement yet to come!
Unread 05-17-2005, 03:26 AM   #6
sp0rk
Rate My Car: 72 / 340
Let me see what I have done on that list...
Wait a minute... Let me see what I haven't done on that list... lol
blah.
Unread 05-17-2005, 03:28 AM   #7
sp0rk
oops
1990 525iA | 28 HP at the crank (feels like it) | H&R Springs | HID lighting | Painted side skirts and bumper bottoms | Shadowline trim | 17" Mak Matrix wheels | CAI | Chip | 20% Rear tint | Clear front turn signals
see pics at my cardomain site:
http://members.cardomain.com/sp0rkage
Unread 05-20-2005, 05:21 AM   #8
kiwi535
That look's awfully familiar....E34.net????Hell a lot of that stuff will go wrong on ANY car....
ooops my bad,I just noticed the aknowledgement
Unread 05-01-2006, 08:57 AM   #9
euro driver e34
Name: euro driver e34
Your Ride: 1994 525i
It seems like the U.s. models have all of these engine and suspension problems? Unlike my car which seems to have minor interior electrical problems. But the hinges on the glove boxes are junk it drives me nuts!
Unread 05-01-2006, 11:31 AM   #10
Storamin
Storamin's Avatar
Title: Road Kill
no stock bmw suspension is good. replace immediately.
Unread 05-01-2006, 02:42 PM   #11
dinan540
dinan540's Avatar
^^^^agreed.
540i with some mods
Unread 03-23-2011, 04:34 AM   #12
Remo
Your Ride: 1990 520i
A GREAT article
I happened onto this article just searching the net. Very interesting info, especially about the water pump and why it should be replaced. Seems he runs a repair shop.
The BMW M50 engine series is a very durable powerplant. The frequency of actual failure is very low considering the number of these cars that we service. Even with repeated bouts of overheating, they seem to survive well. The least common cooling system failure is the head gasket, or at least leakage in the head-to-block interface. In this article, Iíll cover the diagnosis, repair and prevention of these failures, but it will be up to you to convince your customers that regular maintenance and inspection is the only way to prevent expensive failures.
COMMON PROBLEMS
The events leading up to a head gasket failure can almost be plotted on a graph of typical events. The customer complains of overheating, but the coolant level doesnít drop. The fan, belt and hoses all appear OK, and thermostat function tests fine with a non-contact temp probe. The engine temperature spikes at times, but then is normal. The engine does or doesnít overheat at idle, but the temperature climbs quickly at higher engine speeds.
On most M50 engines, the water pump impeller installed at the factory is plastic. For whatever reason, the impeller separates from the shaft or disintegrates and the water pump no longer pumps. In the first case, with the impeller loose, especially with the engine at operating temperature, diagnosis can be especially difficult. Just when you think there is no flow, some coolant starts to move and everything tests OK, temporarily.
Another problem along this same line is that the auxiliary coolant pump for the heater system can circulate enough coolant to provide cooling at idle, but not at higher engine speeds.
Then the problem increases in frequency and intensity, coolant is lost, a leak starts at the plastic thermostat housing or, in a worst case scenario, the upper radiator hose blows off, due to failure of the plastic outlet neck (sometimes caused by over-tightening). Then, a series of overheating events culminate with a severe loss of coolant, a misfire and a customer with a very red face.
At this point you canít pressure-test the system, a block test may or may not have been conclusive and there are still the questions about the water pump, fan clutch, auxiliary fan and switch and a stuck thermostat. Itís usually only after all of these other possible overheat sources are eliminated that a head gasket failure is suspected or indicated.
So now I know why it was overheating. This guy just saved me some bucks.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature, and has no chance of being free unless made or kept so by the exertions of better men than himself."
John Stuart Mill
E34 ice racing jybute E12, E28, E34, E39, E60 4 10-20-2005 01:55 PM
Bought an e34 catalyst E12, E28, E34, E39, E60 14 10-05-2005 03:06 AM
E34? jybute E12, E28, E34, E39, E60 26 09-21-2005 11:13 PM
Sik e34 M5 !!! 1129 bhp Kicks ass of nissan Silvia with headstart defkon99 Video and other Multimedia 7 08-21-2005 02:41 AM
E34 M5 in the House 91m5 M5 13 08-07-2005 07:22 PM
