Unread 08-09-2012, 09:36 PM   #1
jmill90
Your Ride: 91 525i
91 525i
i have a 1991 525i, i do all the maintenance myself and even some of the more complicated stuff. i have run into a problem that so far i have yet to find a way to fix. the car runs good till i get to about 2500 rpm then it spits, sputters and acts like it is running on 4 cylinders. does anyone have any ideals?
Unread 08-11-2012, 01:02 PM   #2
Have you checked all your vacuum lines and hoses? ICV?
Unread 08-11-2012, 09:52 PM   #3
jmill90
Your Ride: 91 525i
I didn't see anything, but i could take a lot closer look. Would it need to be a major leak?
Unread 08-12-2012, 06:52 AM   #4
Even a very thin crack or tear could cause idle issues.
Unread 08-12-2012, 11:47 PM   #5
jmill90
Your Ride: 91 525i
Ok, thanks. will take a lot closer look.
Unread 08-13-2012, 09:09 PM   #6
jmill90
Your Ride: 91 525i
I checked and replaced a ICV hose and took off and closely inspected the other vac hoses. No change. I have also changed spark plugs, coils, injectors, o2 sensor and fuel filter. I did a fuel pressure test and at idle i had 41psi. I also swapped out the check control and DME without any changes. Oh i failed to mention that the car runs great till it's been at operating temp for about 20 mins then it starts acting like it does.
Unread 08-21-2012, 10:15 PM   #7
jmill90
Your Ride: 91 525i
thanks for the ideals. it turned out to be a fuel pump.
1995 525i headlights intermittent radarfxst Lighting 2 01-07-2012 10:16 AM
BMW 525i Auto Steering Rack charles mothiba 5-Series 0 02-08-2011 03:49 AM
advice installing front struts on a '92 525i jeffcloud1960 Tire, Wheels And Suspension Forum 0 01-09-2009 02:39 PM
New 525i QcMarque E12, E28, E34, E39, E60 6 02-12-2008 08:57 PM
