Unread 07-31-2012, 11:56 PM   #1
stephenking
Your Ride: 318ti
ignition delema
just bought my first bmw 1995 318ti
the ignition harness needs to be replaced looks pretty simple the problem is this the two green wire harness the goes to the key switch is broken off the side of the ignition ring, also the key tumbler is shot just spins around needs to be replaced, i know the two green wires are part of a coded key system. my question is this can i get a harness and key tumbler Say with key from my local wrecking yard . is there any way to get the chip out of my old key to make this work. second question is the system going to be lock out because the green wires are ripped off the side of the key cylinder.and was tried to start without those wires being close to the key
Unread 08-01-2012, 01:36 AM   #2
You can get a tumbler from the junkyard. You just have to switch over the insides from your tumber so your key will still work, or get the whole car re-keyed. Which is not cheap.
Have you tried starting it since the green wires were disconnected?
Unread 08-01-2012, 09:52 AM   #3
stephenking
Your Ride: 318ti
yes i tried starting it with the green wires disconnected it took Mr a while to figure out where they went too
will it be obvious what inside parts will need to be switched over. also is the car going to be locked up because i tried to start with the green wires off?
Unread 08-02-2012, 11:31 AM   #4
stephenking
Your Ride: 318ti
any help out there
Spinning Ignition barrel repair David Mc E36 12 10-05-2011 10:00 AM
Ignition tumbler difficult to turn and doesn't come back to ON position easily Alex 1993 525i auto E12, E28, E34, E39, E60 1 08-19-2010 09:52 AM
Ignition set DSP543GP E36 8 07-01-2010 02:09 AM
One black spark plug - ignition or injection fault? maxallan E36 6 05-20-2010 01:51 AM
Plasma Ignition System Rooz E36 3 03-15-2006 11:13 PM
