Unread 07-19-2012, 07:24 PM   #1
schleyt
Your Ride: 1991 525
2007 525i automatic transmission leaking
The transmission sealing sleeve is leaking at less than 45,000 miles on the car. Apparently this is a common problem according to two different shops that I went to. Has anyone else had this problem? It seems like a manufacturing defect for a transmission with lifetime fluid to leak so soon.
Any information would be appreciated .
Thanks, Tom
Unread 07-20-2012, 06:56 AM   #2
What part are you referring to exactly?
Unread 07-21-2012, 07:41 AM   #3
schleyt
Your Ride: 1991 525
It is a transmission sealing sleeve. A $400 fix.
Unread 07-21-2012, 11:06 AM   #4
Do you know the part number or have a part diagram?
Unread 08-14-2012, 11:23 PM   #5
schleyt
Your Ride: 1991 525
No, I do not have the part number for the 2007 525i automatic transmission leaking seal.
I am just surprised that no one in United Bimmer has not had this problem. Both BMW shops that I went to said that this is a common problem. I thionk that BMW should replace the seal since the car had less than 45,000 miles and it seams tobe a common failure.
Unread 08-24-2012, 03:40 PM   #6
SD5Series
Your Ride: 2007 525i
I have a 525i 2007
The dealership:
"There are 2 oil leaks, one at the oil filter housing on the left side of the engine block & one at the transmission mechatronics sealing sleeve. The oil filter housing requires replacement of the seals & the transmission leak replacement of the mechatronics sleeve & pan. I don't recommend either repair be performed without a lift. The mechatronics sleeve a very specific repair measurement. If not placed correctly your car will not start. Of the 2 leaks your transmission leak should be repaired first."
Found an indi Certified BMW mechanic that is hooking up all this and then some for only $450. I already paid for all the parts down below. Repairs should be started this weekend or next weekend depending when all the stuff come in. I'm not paying $2300 to do all that stuff at a stealers + what it cost to do everything else. All parts are OEM. ZF and INA are original parts on the BMW
24-34-7-588-725 SEALING SLEEVE (1) --$13.66
But I am also doing all this other work that's included in the $450
24-11-7-571-217 OIL PAN W (1) -- $133.97 ZF
24-11-7-552-108 TORX SCRE (24) --$43.44
83-22-2-220-445 TF 1375.4 (6 liters) --$162
11-42-7-525-335 GASKET:11 (1) --$9.06
11-42-7-537-293 GASKET:11 (1) --$9.06
11-53-7-549-476 Thermostat + the screws (1) -- $77.15 INA
11-28-7-530-314 Mechanical Belt Tension (1) -- $77.93
11-28-7-628-650 Belt (1) -- $28.77
BMW Coolant (2 Gallons) -- $37.12
SAF-XO (2 liters) -- $40.00
spark plugs FR7NPP332 (6) -- $58.25
Using forums, you never know who might be using it. I am glad he was a BMW certified mechanic that works for a BMW stealership to do the work for me on the side.
Automobile pits BMW 1M against M3, chastises the automatic transmission scooter BMW News And RSS Feeds 0 06-23-2011 08:30 PM
Problems with automatic transmission 745i 2002 chrissoyland 7 Series (E23, E32, E38, E65, E66) 1 09-03-2010 01:49 AM
323i automatic transmission problems jlengstr Southeast Region 0 01-25-2010 07:19 PM
Sam's reasons why not to buy automatic iamcreepingdeath BMW General Discussion 30 02-18-2008 12:08 PM
