Unread 06-25-2012, 08:12 PM   #1
bpress365
Your Ride: 1998 5 / E39
A few overheating questions
I have a 1998 528i that is running hot ONLY sitting still. Say picking up lunch at a fast food drive thru. If I have the AC I have to turn the car off if it takes any time at all, but one back on the road temp return to normal. My questions are should my cooling fan run only when the AC is on? If I had air in the system wouldn’t it run hot all the time? Is there a test for a faulty fan switch? Thanks in advance
Unread 06-28-2012, 10:14 AM   #2
If its only overheating when sitting still then it's most likely that your fan clutch has worn out. When it fails the fan spins freely and doesn't pull air in to cool off the engine. A good way to test this is take a small newspaper or flyer and roll it up. Then with the car running slowly insert the newspaper into the spinning fan blades. Do this slowly and carefully so you don't snap a fan blade. If the paper stops the fan then your fan clutch needs to be replaced.
Unread 06-28-2012, 02:17 PM   #3
bpress365
Actually due to my misunderstanding of overfilling the coolant reservoir all I needed to do was add coolant, and presto. Dopey ol me…… Thanks for your reply
Unread 06-28-2012, 07:25 PM   #4
Well glad it worked out and you didnt need to replace anything.
UK deputy PM says Murdoch must answer questions scooter    Latest News 0 07-14-2011 02:40 PM
E36 328i 1998 Mystery Overheating.. bmw328i98 E36 7 12-21-2010 12:29 PM
E39 Overheating jay E12, E28, E34, E39, E60 10 03-04-2008 09:08 AM
Overheating problems! Oh my! digismack E36 24 01-07-2007 12:05 AM
Bulb Replacement/ and other questions. ///Menace328i E36 0 05-13-2005 10:07 AM
