Unread 06-25-2012, 03:02 PM   #1
Britar
Your Ride: 1993 325is
Tried to check my diag codes - weird result
I have another question.
I read the sticky about checking for any stored codes via the On key + 5 accel presses.
I followed the procedure and seems to get a strange result.
The Check Engine Light (CEL) flashed to start.
Then it gave a long flash a pause and then a quick flash.
It seems to just repeat this pattern over and over. long flash - long pause, quick flash, long pause - repeat.
Am I just reading it wrong?
Brian
Unread 06-25-2012, 04:27 PM   #2
Thats the procedure for OBDI cars.
The CEL should flash, followed by a pause, then the flashes for the code (if any). Theirs a couple youtube videos on it, so you can see what it looks like.
Unread 06-25-2012, 04:34 PM   #3
Britar
Ok, thank you.
The procedure did seem to activate a diagnostic mode (lots of clicking and such) plus the blinking CEL. But I'm going to go with no codes = good.
I don't have any reason to suspect a code, just checking.
By your response I take it mine may not be OBDI?
Brian
Unread 06-26-2012, 08:10 AM   #4
No yours is OBDI. I was saying that you were correct in that the procedure you used was correct.
Pre 1995 is OBDI. 1996 and newer is OBDII
Unread 06-26-2012, 09:04 AM   #5
Britar
Thanks.
In other news, some emery cloth, a few new bulbs, and dielectric grease seems to have cleared up my rear light gremlins.
BMW Inspection I & II Service DEATH2000 E36 0 03-26-2012 10:07 AM
Weird Check Engine Glitch wishkah353 E21, E30 0 11-23-2010 04:30 PM
OK - getting codes, CHECK ENGINE light works, but it's not on! volvodefector79 E36 1 11-13-2007 06:46 PM
