Unread 06-18-2012, 12:40 PM   #1
Hatori Honzai
Your Ride: 1998 328iC
E36 Driver's window problems; airbag light
Doing minor repairs on my recently purchased 1998 328iC with 158000 miles. (Previous owner bought it at auction after a minor crash to passenger door. He replaced the outer door panel, trim, air bag, and the rag top.)
1. The driver's power window:
  • Sometimes makes popping noise when rolling up or down.
  • Most of the time will not roll all the way up when using the rocker switch that controls all the windows. It will begin to roll up and then reverse itself while the other windows close. Releasing the master rocker switch and pressing it again will close the driver's window. This happens if the convertible top is already in the open or closed position.
  • Will not roll all the way up when closing the convertible top. It will stop about halfway or reverse itself.
  • When opening the convertible top, all the windows will appropriately lower themselves during this process, but the driver's window is about an inch lower than the others. All the windows appropriately raise to their full height if the convertible switch remains engaged.
  • After this point, I can lower all the windows with the main rocker switch, but if I raise them again, the driver's window will start to raise and then either stop halfway up or reverse itself to the completely open position. Releasing and pressing the main switch allows the driver's window to close.
2. The airbag indicator light stays on after the engine is started and running.
Unread 06-19-2012, 12:42 AM   #2
Its possible the tracks for the window are out of alignment. One other thing i can suggest, is when the parts in the door were replaced did they teach the car to learn the door features again? Sometimes the computer needs to relearn it.
Check the airbag connectors as they may be loose.
Unread 06-19-2012, 10:20 AM   #3
Hatori Honzai
TFR. I will check the window tracks. For the airbag, something tells me they did not follow procedures. A couple of months back I read something about the airbag reset steps.
Unread 06-23-2012, 11:22 AM   #4
You may have to bite the bullet and have the airbag light reset with a reset tool (different from the oil service/inspection one). I think a prolonged interruption in the electrical supply is interpreted as a fault and the light comes on. At least that was what I experienced a couple of years ago.
Unread 06-26-2012, 10:12 PM   #5
Hatori Honzai
Reset tool
It figures that my model has a different tool for that. I think I'll contact local Bimmer clubs and see if anyone has a reset tool. Was your issue due to a long period of time before installing a new airbag or from having the battery cables attached while changing the airbag?
Unread 06-26-2012, 10:32 PM   #6
No, not from any work being done on the airbag (by the way, I think it's advised to disconnect the battery if doing anything with the airbag), I was having the rocker panels replaced and some other work done on the car, and the battery was disconnected for something like a week or so. The car started up just fine after that, but for whatever reason the airbag light came on and stayed on for longer than the few seconds of the test cycle. It would eventually go out, but I couldn't get an inspection sticker like that. Took the car to my service guy who has the proper reset tool and that was that, things returned to normal and have been that way since.
1994 318i E36 Electric Window problems Clyde E36 1 09-05-2011 02:46 PM
7 Series E38 - audio working/ not working - airbag light flickering... Durny 7 Series (E23, E32, E38, E65, E66) 0 06-06-2011 05:29 AM
E36 power window problem techmike E36 7 05-15-2011 06:45 AM
E36 Window Switch light replacement JoshsE36 E36 3 04-10-2010 08:43 PM
