Unread 05-28-2012, 02:31 AM   #1
fishgetter1
Your Ride: 1985 325e
maf sensor
When i install my new maf should i disconnect the negative post on the battrie first ? After installing is there anything else that i should do besides hook up the plug in
Unread 05-28-2012, 07:26 AM   #2
Anytime you work on the vehicles electrical system you should disconnect the battery. This helps to prevent injury and damage to yourself and the car.
Have you gotten a copy of the E30 Bentley Service Manual yet?
Unread 05-28-2012, 09:43 PM   #3
fishgetter1
If i unplugged the old one before i disconnected the old one and then plunged it back up do you think that the computer will reset it self when i install the new one. i also started the car after i plugged it back up
Unread 05-28-2012, 09:47 PM   #4
You should leave the battery disconnected for at least an hour to allow the computer to reset itself. With a new MAF the notice in engine performance should be immediately noticeable
Unread 05-28-2012, 09:51 PM   #5
fishgetter1
Thanks for your response you seem to always to have a answer . THANKS
Coolant Temp sensor dilemma Serge E36 1 07-23-2009 08:48 AM
SRS/ Airbag light - Seat Occupancy sensor David Mc E36 0 02-16-2008 08:31 PM
MAF sensor cleaner works then doesn't. gldfshkpr E36 15 02-10-2008 05:53 PM
MAF sensor cleaner? Dudesky Non BMW General Automotive Discussion 0 03-03-2007 03:30 PM
