Unread 05-18-2012, 09:15 PM   #1
EmKay
Your Ride: 2003 BMW E46 318i 2.0
Cool My E46 Engine Problem
Hello guys, I am EmKay, a new member in this community. I have problem on my 318i 2.0 E46 N42 engine. I have sent my car to workshop to repair the water pump because of leaking (the mechanical seal worn out). However, after the repair, I noticed the engine become too noisy and make make me wonder what was actually happened. It is very hard to describe about the noise. Can any one help me on this?
EmKay
Unread 05-23-2012, 08:39 AM   #2
Can you describe the noise? Click, tap, chatter, whistle?
I am not familiar with the 318 engine, but the most common noises on the six cyl engines are the tensioners (actually the tensioner pulleys) on the serpentine belts. He removed the belts, so disturbing old tensioners may have made one start to chatter.
I recently replaced the water pump on the wife's 330, and it developed a sort of odd whistle or moaning sound. I suspect that I created an air leak, perhaps in the rubber hood over the throttle body. Those get old and brittle and crack eventually. The car runs perfectly so I have not spent much time looking for the problem yet.
Unread 05-29-2012, 12:14 PM   #3
What else did they replace? Did they replace the serpentine belt as well? Its possible that due to age its worn out and is causing the issue, or their is something on the belt like fluid causeing the issue.
Bmw e46 engine swap rashawn13 M3 3 02-10-2012 08:07 PM
2004 E46 320Ci - Passenger Seat problem rsc85 E46 0 08-25-2010 08:12 AM
Pictorial DIY: BMW E46 Fan Clutch Removal & Engine Belts Change For Automatic Cars delmarco E46 4 04-29-2010 03:16 PM
E46 Door Handle Problem - Please Help kentukred E46 1 11-06-2007 12:33 AM
