Unread 10-16-2005, 06:53 AM   #1
Backup Light Switch DIY
All the usual disclaimers apply . . in short, do this at your own risk, blah blah blah. Also, people have different methods of doing this job, and I have mine.
Backup lights don't work? Can't see behind you at night? If your bulbs check out okay, then the next step is to replace your backup light switch. This should take no more than a few minutes, and the switch costs under $10. This is probably the shortest and easiest DIY, but I wrote it anyway for those not so mechanically inclined
Jack up the car to give you more room to get underneath. Photo shows the switch on the driver's side of my Getrag transmission. On ZF trannies, it will be on the passenger side towards the front.
To pull the wire harness off, feel for the metal locking clip and push in. Then pull the harness off the switch. Photo shows the harness off, with the metal clip visible (sorry for the blurry picture).
You'll need a 3/4" box end wrench to unscrew the switch (inset photo), since not much else will fit in that space. If you use a socket set, you may need a deep well socket, but it might not fit with the wall of the tranny hump so close by.
Say goodbye to the offending switch, and pop in the new one. Official torque is 15 ft-lbs, but a smidge past hand tight will do just fine. Plug the harness back in, lower the car, and you're done!
Unread 10-16-2005, 06:58 PM   #2
TJsBimm
Rate My Car: 224 / 340
Your Ride: 97 328i
Send a message via Yahoo to TJsBimm
Sweet if that ever happens to me I'll know where to go! I was thinking to myself that was your problem.......We have light again!!!!!!
Unread 10-17-2005, 03:59 AM   #3
Thumbs up "Dr Dudesky to you..."
D-sky, you should be "Dr Dudesky".. One of my buds at an Orlando BMW dealer says you should write campaigns & training for BMW. I sent him a couple of your samples & he agrees they're better than Bentley & OEM.. You missed your calling bro...
On an afterthought, - I don't know how readers (outside of UB) would take the occassional "WTF??"
Unread 10-17-2005, 07:02 AM   #4
Ha ha thanks
Unread 10-17-2005, 12:02 PM   #5
Very nice. This should also fix the occasional "Brake light circuit error" or whatever on the OBC, shouldn't it?
If so, can you add that little comment to the top, and I'll add it to the knowledge base. I know I personally was looking for a DIY a long time ago like this when I needed to replace mine, because of that message.
Unread 10-17-2005, 05:38 PM   #6
Well, the one on the OBC is the Switch, this DIY is for the sensor
Unread 10-17-2005, 06:31 PM   #7
No, this is for the backup lights not the brake lights
Unread 10-17-2005, 07:36 PM   #8
Yeah, I just realized that, haha. I'm an idiot.
Making it into a knowledge base DIY now....
Edit: Added!
http://www.unitedbimmer.com/kb-e36-r...hts-switch.php
Thanks Dudesky.
Unread 10-17-2005, 09:03 PM   #9
Di nada
Unread 05-31-2011, 08:27 PM   #10
Philly325ic
Your Ride: 1988 BMW 325ic
Thanks!
I'm brand new here but this was awesome. I know it's more then a few years old but I had an intermittent back up light issue on my new (to me) 88 e30 Cabrio. No more though. Thanks!
Ryan
FS: Brake light switch Dudesky Bmw Cars For Sale/Wanted 7 12-13-2006 07:15 AM
How many forum members does it take to change a lightbulb? bmwcrazy Comedy Collection
6 11-20-2005 09:31 PM
