Unread 04-22-2012, 01:46 PM   #1
beamer01
Your Ride: 1991 bmw 320se
Bonking Noise
Hi all this is my first post.so i hope i do it right.
I have a bonking noise at the rear end when going over bumps or rough road surfaces any help to fix it would be nice
BEAMER01
Unread 04-24-2012, 11:12 AM   #2
Lift it and look for loose exhaust mounts, you might have a bad center support bearing, I've also seen the rear sway bar slip out of its mounts.
Unread 04-26-2012, 06:23 PM   #3
Could also be a worn out Rear Shock Mount (RSM). Best way to find out is to get under the car and trying to find play in any of the components.
Unread 04-28-2012, 12:46 PM   #4
328is
Your Ride: 1998 328is
can you tell which side of the vehicle its coming from? are the anti rattle clips on the brake calipers installed or the spare tire secured properly?
Unread 04-29-2012, 11:58 AM   #5
beamer01
Hi 328is
It is comming from the righthand side i have check the spare and brakes..
Unread 04-29-2012, 09:29 PM   #6
Also check rear trailing arm bushings. Replace in pairs.
Whining Noise in A/c System 8 ball 7 Series (E23, E32, E38, E65, E66) 0 11-14-2011 06:32 PM
E36 BMW 325 auto transmission/gearbox noise? m1k3o 325auto BMW General Discussion 1 09-22-2010 10:55 PM
BMW experimenting with electronic noise canceling tech for diesels scooter BMW News And RSS Feeds 0 05-31-2010 04:50 PM
Rear End Noise - 2006 325xi Ebby1600 E90 11 12-07-2009 11:37 PM
325i noise from engine/trans at idle cold buckles E36 1 10-20-2008 04:31 AM
