Unread 10-14-2005, 08:31 AM   #1
brian97e39
FM Radio Problems
I have a 1997 528, with the DSP. For some reason the FM stations sut on and off, and Im in a large city where its never done this before. I sounds like a loose wire on the anntena or something but I dont know where tyo start looking. It does not not out if im in the weather band mode, which seems starange. Any ideas?
Brian
Unread 10-14-2005, 09:32 AM   #2
If I'm not mistaken, your antenna splitter is in your drivers' side rear post (rear left pillar) I'ld check w/BMW or someone who speacializes w/car stereos to be sure. Your actual antenna is the stripes across your rear window parrallel w/ rear window defrost lines. Some window tints with metallic layers will fluctuate your radio signals and the splitters are known to come loose on occassion - somethings you might check
Unread 10-14-2005, 09:35 AM   #3
brian97e39
I will look into that, although I dont have tint...yet...but I will look into that connection. I was just out driving and noticed that not only does the weather band work properly but so does the am stations, just seems wierd that it would only be fm, but Im still going to look into it.
Unread 10-14-2005, 10:23 AM   #4
It's more than likely your splitter. It has seperate connections for AM & FM reception. You didn't happen to have cleaned the inside of your rear window lately or had it detailed? Because you/they might have scratched one of the "strips" which would affect reception.
Unread 10-14-2005, 10:38 AM   #5
brian97e39
I just bought the car about a week ago, i got it through my Uncles BMW dealership...so I dont think they would have messed it up. But that splitter sounds like it could be the problem, does anyone know how to get in there?
Unread 10-14-2005, 12:10 PM   #6
First verify from BMW or stereo folks that it's in that location. (that's where it's at in most) If it is in rear post, rear seat has to be removed & weatherstrip and a few screws & the interior cover panel comes off. Then it's just a visual inspection - you'll probably see a wire hanging off or just loose. It's simple once you get to it. (another good source would be check with a Best Buy car stereo installion facility - they're good at shating info)
Unread 06-15-2011, 04:59 PM   #7
barbcoble
Your Ride: 1997
Smile
Hello all. I have a 1997 318i, and am having problem with the radio. We got a new radio, but can not find the weather band antenna. We have the main wires, in a cluster, the antenna wire from the outside antenna, but can not find the weather band wire. Can someone please tell me where it might have hiden itself.
Unread 06-15-2011, 05:14 PM   #8
barbcoble
Your Ride: 1997
I have a convertible so the antenna is not in the window, when we got the new radio, it came with the cluster, antenna, and weather band, all cut off, so we know we should have the other wire, but can't find it. Tks.
Google Going Radio komodo United Off Topic  **FOR MEMBERS ONLY** 5 02-04-2006 03:43 PM
FM radio help Spieluhr Car Audio and Electronics 3 11-12-2005 02:40 PM
XM Radio Announces 5 Million Subscribers komodo Car Audio and Electronics 12 10-07-2005 12:36 AM
XM Radio Question Rooz Car Audio and Electronics 6 09-12-2005 06:29 PM
New tires, New Radio augusta325is E21, E30 4 08-24-2005 02:33 PM
