Unread 04-09-2012, 08:10 PM   #16
Wow. I have never It that bad before. Backfiring thru the intake can only be caused by a few things. Extreme lean condition(vacuum leak, or no fuel), if ignition timing out of wack, or something mechanical like a jumped timing chain.
Look under the intake manifold. These hoses should be connected.
Unread 04-10-2012, 07:34 AM   #17
antymated
Your Ride: 93 bmw 325i e36
i will double check any vacuam leaks. and i was looking at the Idle Control Valve do you think its possible because of that?
Also how do you check for ignition timing and for a jumped timing chain...
also how to check idle control valve if still working...
"note": i took the idle control valve out and using possitive and negative and all it did was vibrates...and even on the engine...it still just vibrates... does it mean it still good?
would you hear a click sound...because i believe there is a click sound before every backfires... (if you listen on the video you probably can hear it before you see the flame).
Thanks for your help Death2000....
Unread 04-10-2012, 09:47 AM   #18
I doubt the idle vmcontril valve would cause this. My ICV failed and the car wouldn't idle, not spew smoke. The ICV does need to be cleaned over time though.
Here is the Pelican Parts DIY article on cam timing:
http://www.pelicanparts.com/bmw/tech...aft-timing.htm
Here is a thread from Binmerforums which delves into some more detail and might help too.
http://forums.bimmerforums.com/forum....php?t=1247693
Unread 04-12-2012, 01:23 PM   #19
antymated
OK!...thanks for every thing!! Death2000! car dont choke no more....(what it was doing on youtube)...
I think it was a two hose that connects to the intake box...
i hooked up to the intake box and it didn't choke no more!!!!
THANK YOU!!!
BUT!
1. Car starts hard seems like its not getting enough car or something...
i turn the ignition car and seems like it will build up air and slowly hear it going to start and then it starts...
and then
1. the rpm idles up and down, up and down... and if goes under the number 1 rpm then it dies?!???
i wonder what it is?
before it wasn't this bad to start it...
i cleaned the ICV with carb cleaner and hooked back up and go worst!!??
could it be the ICV?
2. also engine smokes and smokes comes out of the PCV what could that also be??
3. and is it normal for bimmers to spit out oil from the dipstick when car started?
please help me...and THANKS ALOT!!!
Unread 04-12-2012, 01:54 PM   #20
I know that when my ICV needed replacing it wouldn't idle at all. The car would start, and then immediately die. I had to constantly keep on the throttle a little bit or it would stall. If yours is just idling really rough start with a vacuum line. Disconnect the MAF and se of that fixes it.
The PCV is a valve so check to make sure it's not worn out. As for oil sputtering from the dipstick I've never had it removed with the car running so I wouldn't be able to say.
Unread 04-19-2012, 05:28 PM   #21
antymated
CAR NOT STARTING agian...dam it....
was attempting to start it but didn't...bout a new ICV and PCV just still waiting on the new part and see if that is the problem...bout a new pcv because there is oil that leaks into the hoses connected to the intake manifold...and oil in the intake manifold...
the old pcv still looks new just that there is oil on it...
icv i dont even know if it works or not anymore...wierd!!>!
car is giving me head aches....
it seems as if it is going to start but not starting...it cranks and everything but not starting!!!! wth...its wierd?!?!??
Unread 04-19-2012, 05:30 PM   #22
antymated
also my mass air flow sensor is not working i think cause i did unplug it when it was running and it idle good...
the next day i went and start the car agian it didnt start PERIOD!!! well it did start once after a long long long time...then it immediatly dies and never agian heard it start...
see if next week my ICV comes in and see if thats the problem...hopefully...fingers cross...!!!
Unread 04-19-2012, 07:29 PM   #23
Hopefully. Maybe fuel pump?
Unread 04-19-2012, 07:46 PM   #24
antymated
idk...if it is the fuel pump... there is gas...dam...i have no glue..anymore...hmmmmm...
